Routing issue with Vlans
Hi All,
I have a question and I am not sure where to start troubleshooting this.
Setup:
RouterOS (Router) with 3 Wireless AP’s. One Wireless AP is connected to the router by a Switch (SWOS).
All AP’s radios are managed by CAPSMAN
3 Vlans - 100, 200, 300
Everything works fine on the AP’s connected directly to the Router, but I cannot get Vlan 200 to work on the AP connected to the Switch, but Vlan 100, 300 work fine. I am receiving DHCP from the Router.
Cannot ping from the target device to the router on Vlan 200 and cannot ping the target device from the router either.
However, If I move the target device to Vlan 100, 300 and I can ping default GW and everything works fine.
Where I am confused is that CAPSMAN is managing all wireless interfaces, so they are exactly the same. Considering each wireless interface is going through the Swos (Switch) all on the same port, what could be the issue here?
Where should I start to troubleshoot this? TIA
Sounds like the issue are your switch settings and possibly the router settings to the switch.
In other words post your router config and provide snapshots of your pertinent 260 settings.
