I put ROS 3.10 on a 4526 Soekris and config’ed the interfaces (2). One for local wlan (wlan1) @ 2.4 the other for backhaul (wlan2) @ 5.8. Made the 7 mile link..woohoo! Here is the config:
routed netwoork, not bridged
Firewall: NAT/srcnat out interface wlan2/masquerade
have static dns config’ed
I have several other boxes, mostly RB153’s with pretty much the same type of config (diff ip’s of course) with 2.9 OS and they work fine.
However this particular one seems to refuse to forward traffic past the next node. I can ping it both ways, but when I do a traceroute the starting ip is 0.0.0.0 which, to my thinking, should actually be 192.168.178.1. Is there something in 3.10 I’ve overlooked? After all the others I’ve set up I thought I pretty much had this down to a science, but this isn’t behaving as I suspected it would. Any thoughts?
I have the exact same problem will not forward traffic. Same setup basically, just different IP’s Going to start a new thread about it though and not hijack this one.. O JIC (just in case) did you fix it or figure out what was wrong mite fix my problem as well if you know. Thanks -Jordan
