Routing mark block firewall filter rule?
Hi, i have this situation.
add action=accept chain=forward dst-address-list=192.168.4.0/24 src-address=192.168.1.0/24
add action=accept chain=forward dst-address=192.168.1.0/24 src-address-list=192.168.4.0/24
Now i activate mark routing
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=isp1 passthrough=yes src-address-list=lan1
add action=mark-routing chain=prerouting new-routing-mark=isp2 passthrough=yes src-address-list=lan2
/ip firewall address-list
add address=192.168.1.0/24 list=lan1
add address=192.168.4.0/24 list=lan2
Thats work fine. 192.168.0.1/24 select isp1 gateway and 192.168.4.0/24 select isp2 gateway.
But the first firewall rule not working when the mark routing is enable. For example, before mark routing i can ping any pc of lan1 from lan4…after mark routing enable i can’t (destination unreacheable).
Why??
By the way: What the hack is mark routing?
Gesendet von meinem SM-G928F mit Tapatalk
Your address list for lan2 has the wrong IP address - .1.4 instead of .4.0
Sorry, typing error in the post (not on router os). I corrected
I don’t think you meant dst-address-list=192.168.4.0/24 in firewall filter, either dst-address=192.168.4.0/24 or dst-address-list=lan2.
But the problem is most likely with finding correct route and this should fix it (change it to only your smaller subnets if you have more complex network):
/ip route rule
add action=lookup-only-in-table dst-address=192.168.0.0/16 table=main
Yes, dst-address-list=lan2. Sorry
Thanks, its works! Can you explain me that this route rule do ?
By default, routes go in main routing table. But you also have routing tables isp1 and isp2, both with (most likely) only one route to 0.0.0.0/0. Normally, when you don’t mark routing and you connect to e.g. 192.168.4.x, router looks in main routing table, finds a connected route to 192.168.4.0/24 and uses it. But when you mark routing with ispx mark, router looks only in ispx routing table. And it has only one route, so your packet to 192.168.4.x goes to ISP, only to be dropped sooner or later and you never hear back from it.
The rule tells router to use main routing table for given destination.
Thanks a lot
