So I’ve looked at the various tutorials on using routing-mark.and as far as I can see, I’ve done everything right.
I have a VPN connection set up in the Router which uses IPSec.
The default route for 0.0.0.0/0 to use the VPN gateway is created automatically (add-default-route=yes in the l2tp-client interface).
I would like to push data from specific local IP addresses (e.g. Smart TV) through the “raw” internet connection.
I have created an additional route to 0.0.0.0/0 with the ISP’s gateway specified. The Preferred Source is my public IP. This looks like the automatically-generated route for the ISP’s gateway, but it has a routing mark: “direct”
There is a Masquerade rule for pppoe-out, through which the ISP’s gateway is reached.
I have created the following Mangle rules, where src-address is a test box:
5 XI chain=prerouting action=mark-connection new-connection-mark=direct
passthrough=yes src-address=10.0.32.1 connection-mark=no-mark
in-interface=bridge-lan log=no
6 XI chain=prerouting action=mark-routing new-routing-mark=direct
passthrough=yes connection-mark=direct log=no
7 XI chain=output action=mark-routing new-routing-mark=direct passthrough=yes
When these are enabled, Google (on HTTPS) loads eventually but it takes a long time, and sometimes fails with a QUIC protocol error. Other pages (e.g. whatsmyip.org) don’t load at all.
When calling out to whatsmyip on port 80, Wireshark shows me the SYN going out, the SYN, ACK coming back, then the GET request going out, but then silence from the server until it sends FIN, ACK shortly afterwards.
Any ideas? Do I need to set up an HTTP server in AWS to see if the request is getting out?
Many thanks
- Hugh
