I would like to send all packets for 192.0.2.1, udp, por 51522 over my lte interface. I have put the default route for the lte interface in routing table “default_wwan”:
[admin@SunGate1] > /ip/route/print where routing-table="default_wwan"
Flags: A - ACTIVE; s - STATIC
Columns: DST-ADDRESS, GATEWAY, DISTANCE
# DST-ADDRESS GATEWAY DISTANCE
2 As 0.0.0.0/0 lte1 1
Now assume for a moment that I ignore udp and port 51522 and I want all packets for 192.0.2.1 to be forwarded via lte interface. Then I can just create a simple routing rule:
[admin@SunGate1] > /routing/rule/print
Flags: X - disabled, I - inactive
0 X dst-address=192.0.2.1/32 action=lookup table=default_wwan
All works as expected! However, I cannot do this because I additionally need to filter for udp/51522, so I create a mangle entry in the firewall:
[admin@SunGate1] > /ip/firewall/mangle/print
Flags: X - disabled, I - invalid; D - dynamic
6 chain=output action=mark-routing new-routing-mark=default_wwan passthrough=no dst-address=192.0.2.1
log=no log-prefix=""
But now, when I ping 192.0.2.1, I indeed do see the ICMP echo request being sent through lte1 via the packet sniffer. However, the source address of the IP packets is not the address of the lte interface but the one of the default route! That makes zero sense. Of course, everything breaks.
I have tried adding pref-source to the default route, as well as adding an additional rule like this:
0 routing-mark=default_wwan action=lookup-only-in-table table=default_wwan
But none of them work.
This really can only be a bug in RouterOS? Or what am I doing wrong?
