Routing Marks in Output Chain for IPSEC
Hi, I’m just after a little bit of help regarding a routing problem I have.
I have two connections to the internet via gateways 1.1.1.1 (on interface I-A) and 2.2.2.2 (on interface I-B) and I have two IP routes as follows
0.0.0.0/0 to 1.1.1.1 bound to routing-mark=“R-A”
0.0.0.0/0 to 2.2.2.2 bound to routing-mark=“R-B”
Using mangle rules in the INPUT chain I mark all incoming connections on interface “I-A” with connection-mark=“C-A” and all incoming connections on interface “I-B” with connection-mark=“C-B”.
I then have mangle rules in the OUTPUT chain that mark connections with connection-mark=“C-A” with routing-mark=“R-A” and connections with connection-mark=“C-B” with routing-mark=“R-B”.
If I ping the IP address of the router associated with interface “I-A” from an external point then this responds correctly and I get a reply and if I disable the OUTPUT chain rule marking “C-A” connections with routing-mark=“R-A” then the ping is dropped so the OUTPUT chain is correctly marking the packets and the routing-mark is having an effect and routing correctly by picking up the correct route.
What I don’t understand is that incoming L2TP connections from my remote router do not have the same results.
I can only get these to work if I have the default route on the router (without any connection mark binding) pointing to the gateway the L2TP/IPSEC packets are arriving on. i.e. they appear to be skipping the OUTPUT chain routing-mark logic and defaulting to the default gateway.
Would anyone be able to try and explain this problem for me. I assume it’s something weird with the L2TP connections.
Many thanks, Dominic.
Just for information, whatever was causing this problem was still apparent in v5.0rc9 but has been solved with v5.0rc10
Cheers, Dom.
