I need to route/masquerade a device into a different network.
Configuration:
It is not possible to install a cable connection from the location where the Playstation 4 is to the target router.
Both routers a connected via ether1 interface.
Device (Playstation 4) with IP 192.168.222.251 is connected to a MikroTik RB (192.168.222.1/24)
MikroTik RB (192.168.222.1/24) is connected via ether1 interface to FritzBox (192.168.178.1/24) router ether1 interface
Playstation 4 should there arrive with IP 192.168.178.30
First you need to add one or more IP addresses to RB on ether1 belonging to Fritz’ LAN segment (192.168.178.x), you can’t have same IP address for both network segments (RB’s ‘internal’ - LAN and ‘external’ - Fritz’ segment). You’d have the least complications if using only one - the one that Fritz thinks to belong to PS4 (192.168.178.30), but possibly more than one if other traffic, passing through RB has to use different IP address on Fritz’ LAN.
Then you add masquerade queue in NAT configuration. In case when you only use one ‘external’ IP address on RB, it’s pretty straight forward:
In case when you’ll use several ‘external’ IP addresses on RB, it’ll be slightly different (my guesswork starts here). You’ll need several masquerade actions and order probably makes a difference:
I’ve never set-up RB to do NAT using more than one external IP addresses, hence my guesswork above might be far from correct. Hopefully someone experienced will correct me.
Thinking of it, perhaps there’s another possibility: the switch chip in RB is highly configurable and one can create more than one “sub-switch” grouping a subset of ethernet ports. Default setup is to have ports ether2-5 in a switch group while ether1 is isolated (so called WAN port). If the basic problem you’re trying to solve is lack of ethernet cables while you don’t want to invest in additional ethernet switch, then this might be a way to go (with assumption that PS4 does not have to interact with the rest of devices in RB’s LAN): you can create two bridges inside RB, one spanning ether1 and e.g. ether2 and the other bridge spanning the rest of ports (similar to default setup where there’s single bridge spanning ether ports 2-5). Then you’d hook PS4 to ether2 and it would function as if there was only a dummy ethernet switch between PS4 and Fritz. RB would then route traffic between both bridges (while default setup is to route traffic between britfe and ether1).
Very good input Metod and poi. Thanks for supporting!
Will check tonight after returning from work and will report my findings.
Just few clarifications relative to my infrastructure (hpe I find some tme today to draw a basic diagram of my network).
The RB is configured as a bridge with an own DHCP server. The FritzBox as also DHCP.
The ethernet cable from the RB to the location where the PS4 is, supports also 2 PC’s and 2 Smart TV’s.
@Metod, you mentioned a switch. Not sure how this could help to solve my issue, but I have a very simple managed switch (Netgear Netgear-GS105e v2) and a unmanaged switch in spare.
As I wrote: if PS4 doesn’t have to interact with the 2 PCs and 2 Smart TVs (at least not via ethernet), then it would be easier if you connected it to “WAN” segment of your RB. Either by placing a switch in front of RB (either of yours would do, personally I’d choose the managed one) or by reconfiguring the RB in the way I mentioned in my previous post … and link to video tutorial that @poison mentioned in his post actually illustrates the same concept (with distinction that you don’t have to manually set-up the PS4’s IP parameters, DHCP packets will pass RB in that kind of setup just fine).
The text above applies only in case where in Fritz land PS4 would use different IP address than RB (with other 4 devices behind it). If all 5 devices (PS4, 2 PCs and 2 smart TVs) are allowed only to use single IP address in Fritz land, then you’ll have to use the first case of my post (‘WAN’ interface of RB taking up the PS4 address and NAT everything onto it).
You might want to consider this possibility even if you can use more than one IP address from Fritz land as the RB setup is much simpler with single ‘WAN’ IP address … unless you have to use more than one due to some certain reason.
Ok, (hopefully) only few steps away from the final goal.
ether4 is connected to Fritz!Box, the according devices get their IP addresses from the Fritz!Box and the child saftey function works as expected
ether2+3+5+wlan1 are bridged and QoS is working properly
So most is working now as wanted, except two points:
Common QoS/traffic management for all ether ports - currently QoS for ether4 is not working at all (network 192.168.178.0/24)
Two devices on the Lan-cable connected to ether4 should belong to network 192.168.222.0/24 and not to network 192.168.178.0/24 as they currently do based on the configuration of ether4
Questions:
What to do to have common QoS for all interfaces, including ether4?
What to do to route 2 devices connected to ether4 (network 192.168.178.0/24) to the other network 192.168.222.0/24?
Any ideas how to configure the RB that the remaing topics also work?
Re QoS: I don’t think it’s posible to affect QoS on ROS devices which don’t go through router’s CPU. You have ether1 and ether4 in common switch “domain”, so traffic between those two interfaces doesn’t go through CPU. There might be a way, but I can’t give you any concrete guides: get those two ports in as SW bridge making all traffic between the two to pass through RBs CPU. Then some queue mechanizm may do it’s job.
Re devices off ether4: please describe what do you want to achieve: a) make the two devices to become members of 192.168.222.0/24 or b) have those two devices possibility to reach certain services, available from machines inside 192.168.222.0/24?
If you want a), then you need to connect those two devices either to port ether2, ether3 or ether5. No way around it.
If you want b) and the amount of services is not too big, you can add some dstnat rules to the NAT table on your RB. And possibly add some filters to the FW to limit access to those services to only select clients. dstnat means that in order to use “internal” services externally (internal being 192.168.222.0/24 and external being anything else, including 192.168.178.0/24), clients need to connect to RB’s address and to exported port which is not necessarily the same as “native” service port on the server itself. Example: you want to allow 192.168.178.242 access to http service, provided by 192.168.222.42. In this case you need dstnat rule that forwards TCP port (e.g.) 8080 to 192.168.222.42 TCP port 80. Then your client machine would request URL http://192.168.178.20:8080/
If the amount of services that you want to “export” is bigger, then you might want to think about routing between the two networks, but that would imply end of NATting on the RB device and start of doing NAT also for 192.168.222.0 on the Fritz. Also you would need to add explicit routes for 192.168.222.0/24 to Fritz (which should use your RB as gateway). You would create some FW rules on RB to protect your 192.168.222.0 from the evil rest of your household except for the services you want to “export”.
What about changing the subnet mask or a VLAN setup to access all devices in both networks from every device in both networks?
Read something about these topics and now trying to understand what subnetting or VLAN means for real life…
In your case, using VLANs won’t give you much. Using VLANs has its merrits if you use more than one VLAN-capable switch in the network and you lack the cabling and/or ports on the switches/routers. If you only use one VLAN-configured switch (in your case the RB), then you can achieve the same with the L2 setup you currently use. Because: to have connectivity between two VLANs, you need to do routing anyway. In your case, you do kind of routing already, except that currently you are doing NAT instead of “proper” routing. Again: if you’d do routing between the two networks, you’d need to do some additional configuration on the router which is default gateway for 192.168.178.0/24 … or else the devices in that network wouldn’t know how to reach devices from network 192.168.222.0/24.
If, on the other hand, you would enable using VLANs also on Fritz (I don’t know if that is possible at all), then you coud have the connection between the two routers configured as VLAN trunk and you would have freedom to physically connect any device, which logically belong to any of the two networks, to any switch/router while keeping the two (logical) networks separated. You’d still need to do routing between the two (logical) networks, but that could be done by Fritz … I tend to keep all the routing on single device, it simplifies the setup (no need to do static routes towards the other router and NAT towards internet is done for all logical networks at the same time).
You could use VLANs in your case as well, but that would mean configuring VLANs on your end devices (PCs and what not). In that case, you could configure ports to be “VLAN mixed”, eg. accept VLAN tagged packets and have some default VLAN id for untagged packets. In that case you could have VLAN-enabled network even with using dumb switches (e.g. one hanging off your ether4 port) … if the dumb switches support the slightly larger ethernet frames (VLAN tagged ethernet frame is 4 bytes longer than “standard” ethernet frame, if switch is really dumb it might drop frames longer than 1500 bytes). And you could use the VLANs only inside RB (and its vicinity) in this case, no need to bother with Fritz.
You’re asking about netmask … the two address ranges (192.168.178.0 and 192.168.222.0) are quite far away, so the netmask would have to be quite short. On the other hand, this would pose quite a challenge to get the traffic between the two halves of the network pass through RB. Reason: if one device needs to send packet to the other device, which according to IP address and address mask belongs to the same network, it is assumed that packet can be sent directly. Sending device sends that packet with unicast ethernet packet with destination MAC address of the receiving device (first it has to know dst MAC address, discovery is handled by ARP handshake). Which in your case can not because RB is in the way. RB could, in principle, be configured to do proxy-arp … but I don’t know how well it would work as RB would not know in advance about which devices are on which side (proxy ARP works like this: when some device asks about MAC address of a particular IP address, the proxy-arp device answers with its own MAC address. When later it receives packet with destination IP address of the third device, it will route that packet over appripriate interface. But the proxy-arp device needs to know all the IP addresses for which it needs to stand in between).
Let me explain my use of VLANs at my home. Traditionally I had a VLAN-capable switch in my comms room and enough cabling so that any device inside my home could have its own wired connection to that switch. I was using VLANs internally inside the switch to have fast communication between the devices belonging to same VLAN. The switch has a fancy feature (unsymetrical VLANs meaning a given port can belong to more than one VLAN and untag all packets exiting that port) meaning I could do some device separation without any of them being aware of VLANs, including the router.
Then the number of wired devices at a particular place (living room) grew to the point I no longer had enough ethernet cables. So I had to install another VLAN capable device (in my case a RB951G-2HnD) and have VLAN trunk on single ethernet cable between the two devices.
And I really needed VLANs, I needed separate (either physical cables or VLANs) connections for the following services:
home LAN
guest LAN - VAP on WiFi with internet only access and limited speed
IPTV - provider delivers multicast streams in a VLAN so I replicated that particular VLAN nside my home network
internet for the IPTV set-top box - I don’t want to make it a part of my home LAN and I don’t want to expose it to the guest WiFi users
All those VLANs are used by 4 devices: WiFI AP, smart TV, IP set-top box, and home cinema receiver. I needed a smart device already for the second bullet (VLAN-tagged WiFi) and I really didn’t have possibility to run 5 ethernet cables (in case I’d actually install 2 WiFi APs to have two different SSIDs on air).
My current setup (deploying RB device) allows me to do all of that using one ethernet cable. For a while the very same device also did the routing between my home and internet (I get internet via VDSL and I used the existing VLAN switch do create another VLAN for PPPoE connection … I could safely run that through my existing ethernet cables without fear of exposing my LAN to evil internet.
Now I actually have two RB951G-2HnD devices, one acting mainly as router and the other one performing as switch/AP. But I have kind of hardware redundancy: if one device fails, I can run my home network with only two out of three devices (even my 24-port switch can fail, some less important device might become temporarily unconnected) in case of failure .. and that gives me time to purchase another RB device (I’m thinking of cheapest xxxRM device)
