Routing one wifi network via VPN
Hi! I want to enable VPN for all devices that are connected to 2ghz wifi network. And remain devices that are connected to 5ghz without VPN.
I followed guide to VPN setup through Surfshark here - https://support.surfshark.com/hc/en-us/articles/360012906220-Mikrotik-router-tutorial-with-IKEv2
And I managed to do everything until step 15 (IPsec identity is created).
Now, how do I assign VPN to 2ghz network?
It depends on your router’s config. If anything from 2ghz wifi should use VPN, then simple solution is to have it as single interface with own subnet, and just put that in the list.
