Hi all. I have question about routing, IP plans and Bonding two wireless p2p.
Sorry for the picture, it was more easy hand draw ![]()
Now I have simple setup:
Internet - GW Mikrotik ----- 5GHz Mikrotik ***** 5GHz Mikrotik ----- Router Mikrotik — other LANs (on picture only LINK A).
Between every Mikrotik is different subnet and roting is done with RIP help - no need to care about routing/GW on each Mikrotik on way.
I would like to go advanced and add second wireless p2p link and set it up as active backup using bonding.
So i add LINK B and Bonding interface with EoIP thro LINK A and second EoIP thro LINK B (Between routers MTA and MTB).
How to do the adressing now. Still use RIP or another protocol is better for this setup? Put all Microtiks between MTA and MTB (ether1+wlan1) into 1 subnet bridge (subnet A for LINKA and Subnet B for LINKB)?
Make shure, that the traffic to internet will not go thro wireless LINK A or B, but thro BONDING (EoIP1 or EoIP2) interface (so the switching if LINKA fail is working). But still be able access Mikrotiks D-F.
Thnx for ideas.
