I've got a customer with three locations. They did have three linux boxes running RH 9. Two of the machines have an ethernet card and a Sangoma T1 interface. The middle machine has two Sangoma T1 interfaces and an ethernet interface.
The odd part is, is that the linux systems have the sangoma's set in a PtP and using the same IP as the ethernet cards. Because the middle linux box died I got called in to fix the problem. With no backup and little time (and we didn't install the linux boxes) I dropped in a mikrotik box. But to get it to work properly I've got the following setup.
ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.2.1/24 192.168.2.0 192.168.2.255 local
1 192.168.2.1/24 192.168.2.0 192.168.2.255 sangoma1
2 192.168.2.1/24 192.168.2.0 192.168.2.255 sangoma2
DST-ADDRESS G GATEWAY DISTANCE INTERFACE
0 S 0.0.0.0/0 r 192.168.2.1 1 sangoma2
1 S 192.168.3.0/24 r 192.168.2.1 1 sangoma1
2 DC 192.168.2.0/24 r 0.0.0.0 0 sangoma1
3 DC 192.168.2.0/24 r 0.0.0.0 0 sangoma2
4 DC 192.168.2.0/24 r 0.0.0.0 0 local
The above works.... HOWEVER... it is a matter of luck that the interfaces get set as the CANNOT be set from /ip route. Therefore if the machine reboots I'd have to jack with it for a while till the routes fall to the correct interfaces.
One solution is to replace everything with MT's and install proper routes. I don't see them going for this. I'd just like to leave the MT if I can be assured that it won't munge the routing table.
thanks,,
Tom Dodge
dodge@disisit.com
