this might be a noob question, because I am relatively inexperienced with MikroTik, so please have mercy with me ![]()
I have a setup consisting of two small edge VPS Debian machines, a MikroTik RB960PGS and a big Debian server behind that.
The MikroTik Router is connected to the edge servers via Wireguard, the MikroTik Router is the Wireguard client.
The MikroTik Router is connected to the Internet via a bad ugly plastic router I got from my ISP, this device can not be used for anything else in this scenario.
On the edge servers I have HAProxy running, that forwards specific traffic to the big server via the Wireguard tunnels. Incoming traffic is solved for me in that regards.
But I want to run a full mail server on the big server, that was previously hosted on one edge server.
My problem with that is, that the SPF record of my mail domain should not change every time my ISP gives me a new IP address.
I want the fixed IP addresses of my edge servers in the SPF record. So my outgoing SMTP packages must be routed through the MikroTik Wireguard tunnels somehow.
I looked into several posts in this awesome forum, I tried to bundle my wg1 and wg2 interface into a routable interface and set a route on them.
Maybe it is something that I have to do on the edge server, but I have doubts about that. The MikroTik router should IMHO be the routing element here.
I did not manage to get it done properly, there where no outgoing packages traceable in all the tests I did.
Ideally I only want connections that are in the NEW state in TCP and are coming from port 25, 465 or 587 and the IP address 10.10.12.11 to be routed through one of the available Wireguard tunnels.
But it would be OK if all the traffic that comes from 10.10.12.11 would go through them.
To make stuff easier to understand I drew a picture of the setup, I hope that helps.
I also include my censored MikroTik export configuration.
[admin@MikroTik] > export hide-sensitive
# 2024-09-07 10:06:40 by RouterOS 7.15.3
# software id = JSRA-V7Q2
# model = RB960PGS
# serial number = REDACTED
add admin-mac=48:8F:5A:90:XX:YY auto-mac=no comment=defconf name=bridge port-cost-mode=short
set [ find default-name=ether5 ] poe-priority=1
/interface wireguard
add comment=wireguard1 listen-port=37483 mtu=1420 name=wg1
add comment=wireguard2 listen-port=15568 mtu=1420 name=wg2
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add comment=ansible name=server-dhcp ranges=10.10.12.10-10.10.12.254
add address-pool=server-dhcp comment=ansible interface=bridge name=server-dhcp
/routing bgp template
set default disabled=no output.network=bgp-networks
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp1 internal-path-cost=10 path-cost=10
set udp-timeout=10s
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add comment=wireguard1 interface=wg1 list=LAN
add comment=wireguard2 interface=wg2 list=LAN
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=0.0.0.0/0 comment=wireguard1 endpoint-address=444.444.444.444 endpoint-port=4199 interface=wg1 name=peer46 persistent-keepalive=25s public-key=\
"REDACTED"
add allowed-address=0.0.0.0/0 comment=wireguard2 endpoint-address=555.555.555.555 endpoint-port=4199 interface=wg2 name=peer47 persistent-keepalive=25s public-key=\
"REDACTED"
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=10.10.12.1/24 comment=ansible interface=bridge network=10.10.12.0
add address=10.10.10.2/24 comment=wireguard1 interface=wg1 network=10.10.10.0
add address=10.10.11.2/24 comment=wireguard2 interface=wg2 network=10.10.11.0
/ip dhcp-client
/ip dhcp-server lease
add address=10.10.12.10 comment=ansible mac-address=D8:3A:DD:B6:ED:C0 server=server-dhcp
add address=10.10.12.11 comment=ansible mac-address=00:13:3B:10:A6:CC server=server-dhcp
add address=10.10.12.0/24 comment=ansible dns-server=10.10.12.1 gateway=10.10.12.1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=10.10.12.1 comment=ansible name=router.lan
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=forward comment=internet in-interface-list=LAN out-interface-list=WAN
add action=dst-nat chain=dstnat comment=ansible dst-port=8001 in-interface-list=all protocol=tcp to-addresses=10.10.12.10 to-ports=443
add action=dst-nat chain=dstnat comment=ansible dst-port=4002 in-interface-list=all protocol=tcp to-addresses=10.10.12.10 to-ports=22
add action=dst-nat chain=dstnat comment=ansible dst-port=4001 in-interface-list=all protocol=tcp to-addresses=10.10.12.11 to-ports=22
add action=dst-nat chain=dstnat comment=ansible dst-port=4003 in-interface-list=all protocol=tcp to-addresses=10.10.12.11 to-ports=25
add action=dst-nat chain=dstnat comment=ansible dst-port=4004 in-interface-list=all protocol=tcp to-addresses=10.10.12.11 to-ports=110
add action=dst-nat chain=dstnat comment=ansible dst-port=4005 in-interface-list=all protocol=tcp to-addresses=10.10.12.11 to-ports=143
add action=dst-nat chain=dstnat comment=ansible dst-port=4006 in-interface-list=all protocol=tcp to-addresses=10.10.12.11 to-ports=465
add action=dst-nat chain=dstnat comment=ansible dst-port=4007 in-interface-list=all protocol=tcp to-addresses=10.10.12.11 to-ports=587
add action=dst-nat chain=dstnat comment=ansible dst-port=4008 in-interface-list=all protocol=tcp to-addresses=10.10.12.11 to-ports=993
add action=dst-nat chain=dstnat comment=ansible dst-port=4009 in-interface-list=all protocol=tcp to-addresses=10.10.12.11 to-ports=995
add action=dst-nat chain=dstnat comment=ansible dst-port=8002 in-interface-list=all protocol=tcp to-addresses=10.10.12.11 to-ports=80
add action=dst-nat chain=dstnat comment=ansible dst-port=5222 in-interface-list=all protocol=tcp to-addresses=10.10.12.11 to-ports=5222
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
mikrotik_censored_export.txt (6.21 KB)
Thanks in advance
Martin
