Routing problem? new config
Hi, i had a working network last week, then a friend came and helped me, now i have problems.
I have a HEX router connected to my ISP.
I then have a CRS326 connected to the HEX
I can ping from the HEX to the internet
I cannot ping from the CRS - pings to 8.8.8.8 timeout, DNS resolves,
Both config files are below
hEX
# 1970-01-02 00:22:41 by RouterOS 7.14.3
# software id = UCH8-EMCD
# model = RB750Gr3
# serial number = HE908W37YAJ
add admin-mac=48:A9:8A:8D:A1:B5 auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 user=\
<bthomehub@btbroadband.com>
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add address-pool=default-dhcp interface=bridge name=defconf
192.168.88.0
/ip dhcp-client
192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
CRS
# 1970-01-05 13:39:43 by RouterOS 7.14.3
# software id = QWN4-QP7D
# model = CRS326-24G-2S+
# serial number = HDC086D3RF7
add admin-mac=18:FD:74:E6:80:02 auto-mac=no name=bri-lan protocol-mode=none
set [ find default-name=ether1 ] disabled=yes
/ip hotspot profile
/port
set 0 name=serial0
add bridge=bri-lan interface=ether2
add bridge=bri-lan interface=ether3
add bridge=bri-lan interface=ether4
add bridge=bri-lan interface=ether5
add bridge=bri-lan interface=ether6
add bridge=bri-lan interface=ether7
add bridge=bri-lan interface=ether8
add bridge=bri-lan interface=ether9
add bridge=bri-lan interface=ether10
add bridge=bri-lan interface=ether11
add bridge=bri-lan interface=ether12
add bridge=bri-lan interface=ether13
add bridge=bri-lan interface=ether14
add bridge=bri-lan interface=ether15
add bridge=bri-lan interface=ether16
add bridge=bri-lan interface=ether17
add bridge=bri-lan interface=ether18
add bridge=bri-lan interface=ether19
add bridge=bri-lan interface=ether20
add bridge=bri-lan interface=ether21
add bridge=bri-lan interface=ether22
add bridge=bri-lan interface=ether24
add bridge=bri-lan interface=sfp-sfpplus1
add bridge=bri-lan interface=sfp-sfpplus2
add bridge=bri-lan interface=ether23
/ip dhcp-client
add interface=bri-lan
set servers=8.8.8.8,1.1.1.1
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.88.1 \
pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/32 gateway=192.168.88.1 \
target-scope=10
/ip service
set telnet disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system note
/system routerboard settings
set boot-os=router-os
Any help greatly received.
thanks
I found the problem.
The NAT rule was using the WAN interface list. I changed this to pppoe-out1 and this seems to have resolved the issue.
I found this by going through the ‘First time configuration’ help pages one last time.
Why do you have an expensive managed switch but no vlans ???
Please send to me I will pay postage and send you a TPLINK managed switch :slight_smile:
HEX
(1) Would remove this default DNS setting..
(2) If not using IPV6 disable it and can rid of all ipv6 firewall rules and address lists.
(3) I see nothing wrong on the hex so far…
CRS326
-Give the SWITCH a static IP address from the hex ( set static lease, and put it outside the pool, 192.168.88.5 for example.
-Leave the bridge mode to default = RTSP ( not none )
-Why is ether1 disabled?? Assuming ether2 is connected to HEX
-Assuming there is nothing plugged into ether1, and thus recommend configuring it from this port off bridge.
-Get rid of second route in orange, not doing you any good.
RS
add admin-mac=18:FD:74:E6:80:02 auto-mac=no name=bri-lan protocol-mode**=RTSP**
set [ find default-name=ether1 ] disabled=no  name=Off-Bridge1
/interface member
add name=MANAGE
/interface list members
add interface=bri-lan list=MANAGE
add interface=Off-Bridge1  list=MANAGE
set discover-interface-list=MANAGE
add address=192.168.88.5/24 comment=SwitchBridge  interface=bri-lan network=\
192.168.88.0
add address=192.168.55.1/30 interface=Off-Bridge1 network=192.168.55.0
/ip dhcp-client
add interface=ether2  **disabled=yes**
target-scope=10
set allowed-interface-list=MANAGE
apologies I realise I didn’t respond. Thanks very much Anav. I have a working network.
I smiled when I saw your comments around the use 326 and lack of VLANs - I will be adding vlans :slight_smile: hopefully without support
Colin
