I have a problem with mikrotik routing. I set up Dual wan PCC routing and Vlans on ether5 LAN interface. There is also ip cameras connected on ether6 interface. The problem is that users from vlans can not connect to ip cameras and can not ping them. I am not able to set up vlan for ether 6 interface(have no smart switch after router). Can you help me please with this problem, i need to ping camera network (192.168.1.0/24 from vlan 100/110). Here is a network map screenshot. https://prnt.sc/swciqd . Thanks
