hi everyone
given info about a problem
1 - i have a server with IPv4:192.168.50.100/24 connected to a port of routerBoard
2 - i have an connected LTE tp-link modem to router and the server has internet through by srcNat it (Not default gateway)
3 - i have another ISP intranet connected to the router and set as default gateway also has static IP
question is :
if srcNat(internet) is enabled for the server , then a dstNat(by intranet) access for http port on the server is not working .
/ip firewall nat add chain=srcnat src-address=192.168.50.100 action=masquerade out-interface=LTE-internet
/ip firewall nat add chain=dstnat protocol=tcp dst-port=80 in-interface=pppoe-intranet action=dst-nat to-addresses=192.168.50.100 to-port=80
but is disabled dstNat works correctly.
so how can i do this case?
thanks in advance
I think you are confused and/or your config is wrong.
Also draw a network diagram
