Hi There
I have not been able to find a topic like this, so i am creating it.
i want to know if this is possible first of all, and if it is how you would go about it?
Firewall
x86 PC with level 4 lic
2x PCI NIC
Objective: route packets to two DSL connections from one NIC while using the other NIC for the Local LAN.
DSL1 = Non-Static DSL with lower latency (Fiber) - For general internet access
DSL2 = Static IP DSL with higher latency (Satellite) - For public access to our servers, web page and e-mail
Problem: I cannot access my router from the internet on it’s Static IP for trouble shooting and configuration
Synopsis: The default gateway is set to the low latency non-static DSL connection, and that works fine till i want to access the router from home or when i am away from the office for maintenance or trouble shooting as it will not respond via the non-static connection on a static IP.
if i can do this with out buying any new equipment that would be great.
Thank you
