Routing problem
I am trying to set up a RB433 where the ETH 3 is on 192.168.1.xxx and the router board is on 10.0.0.xxx. I can ping the gateway on 192.168.1.xxx from the internal bridge but not from any other ports. anyone have any ideas?
Richard
Sorry, but that sentence makes no sense to me.
Instead of describing what you’re trying to do can you please post a network diagram, and the output of “/ip address print detail”, “/ip route print detail”, and “/ip firewall export”? And “/interface print” together with a description of what is what - you’re mentioning bridging?
how do I copy text from telnet to paste on forum?
Richard
That depends on the telnet application you’re using to access the router. I’d suggest using Google to answer that question.
RB433 Eth 1= 10.0.0.xxx Eth 2=10.0.0.xxx Eth 3= 192.168.1.xxx Wlan 1 = 10.0.0.xxx
[admin@MikroTik] /ip address> print
ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.1.200/24 192.168.1.0 192.168.1.255 ether3
1 10.0.0.1/24 10.0.0.0 10.0.0.255 bridge1
2 10.0.0.2/24 10.0.0.0 10.0.0.255 wlan1
[admin@MikroTik] /ip> route print
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 192.168.1.1 1
1 ADC 10.0.0.0/24 10.0.0.2 bridge1 0
2 ADC 192.168.1.0/24 192.168.1.200 bridge1 0
[admin@MikroTik] /ip firewall> export
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
This may be part of it:
You have two interfaces with the same subnet. That causes some routing problems.
I have removed :- 2 10.0.0.2/24 10.0.0.0 10.0.0.255 wlan1.
Still no luck.
Richard
What ip/subnet did you assign to wlan1 instead? What other interfaces are you trying that fail? I see ip/subnets assigned only to the bridge and wlan1 (if you replaced it rather than removed it), so those will be the only ones that will work.
I noticed there is an ip/subnet assigned to ether3, but the route shows that ip/subnet routed to the bridge. ??
0 192.168.1.200/24 192.168.1.0 192.168.1.255 > ether3
and
2 ADC 192.168.1.0/24 192.168.1.200 > bridge1 > 0
