Routing Problem
Please, help me.
I have MK router with 6 peers. One of them connect me to netwok 200.x.x.0/23 directly (trought a cisco router into my AS). The problem is that the MK router show me that:
DST-ADDRESS PREFSRC G GATEWAY DISTANCE INTERFACE
1319 Db 200.x.x.0/23 r CISCO_MY_AS 200 red_acceso
1320 ADb 200.x.x.0/23 r IP_PROVIDER 30 provider
where
CISCO_MY_AS is a router into my network, in the same datacenter. This router run iBGP against the MK router.
IP_PROVIDER is the peer of one of my providers connected directly to MK.
The point is, I need to route this network (200.x.x.0/23) trought CISCO_MY_AS peer.
Do you undetstand my problem ?
Thanks a lot.
Regarding to the last issue, why mikrotik chooses eBGP than iBGP ?, how do I set mikrotik to choose iBGP than eBGP ?, is it possible ?.
This is good for your education: http://wiki.mikrotik.com/wiki/BGP_Best_Path_Selection_Algorithm
And this is a solution to your problem: http://wiki.mikrotik.com/wiki/BGP_Case_Studies_1 (search for “routing filters”)
Good luck,
Eugene
Eugene, thank you very much !, i’m going to try.
