Routing problems
Hello everybody,
I’ve been configuring my Mikrotik RB1100AH as a router for some time now.
For a short time now it happens occasionally that I can not reach websites.
By means of ping I get the IP address, but I can not establish a connection.
 ping tumblr.com
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 66.6.32.31                                              timeout
    1 66.6.32.31                                              timeout
   sent=2 received=0 packet-loss=100%
My guess: Is the problem with the firewall settings?
Thanks for any solutions or suggestions
tumblr is not a good example, it blocks ping requests, as some other sites do too. can you navigate on those sites? Also, please put your firewall rules (ip firewall filter export hide-sensitive) so we have a better idea of what might be going on.
Although I can call the website, but the TLS handshake takes quite a long time.
I have also tried other websites to call, it usually takes a long time.
In these cases I do not get the whole content of the page displayed or “server not found”.
# oct/03/2018 16:07:55 by RouterOS 6.42.6
# software id = EBDI-CZTA
# model = 1100AH
# serial number =
add action=passthrough chain=forward comment="Allow NTP" dst-port=123 out-interface="WAN A1" protocol=udp
add action=jump chain=forward jump-target=icmp protocol=icmp
add action=accept chain=icmp comment="Allow Echo replay" icmp-options=0:0 protocol=icmp
add action=accept chain=icmp comment="Allow Net unrechable" icmp-options=3:0 protocol=icmp
add action=accept chain=icmp comment="Allow Host unreachable" icmp-options=3:1 protocol=icmp
add action=accept chain=icmp comment="Allow Host unreachable fragmentation" icmp-options=3:4 protocol=icmp
add action=accept chain=icmp comment="Allow Source quench" icmp-options=4:0 protocol=icmp
add action=accept chain=icmp comment="Allow Echo request" icmp-options=8:0 protocol=icmp
add action=accept chain=icmp comment="Allow Time exceed" icmp-options=11:0 protocol=icmp
add action=accept chain=icmp comment="allow parameter bad" icmp-options=12:0 protocol=icmp
add action=drop chain=forward comment="Drop TFTP,PRC,NBT,NFS,BackOriffice" dst-port=69,111,135,137-139,2049,3133 protocol=udp
add action=drop chain=forward comment="Drop TFTP,RPC,NBT,CIFS,NFS,Netbus,BackOriffce,DHCP" dst-port=69,111,135,137-139,445,2049,12345-12346,20034,3133,67-68 protocol=tcp
add action=reject chain=forward comment="Drop NSFW" layer7-protocol="Block NSFW" protocol=tcp reject-with=tcp-reset
add action=reject chain=forward comment="Drop Stream" layer7-protocol="Block Stream" protocol=tcp reject-with=tcp-reset
add action=passthrough chain=forward comment="Allow Internet" dst-port=443,80,53 protocol=tcp
add action=passthrough chain=forward comment="Allow DNS" dst-port=53 protocol=udp
add action=reject chain=forward comment="Drop Dump" layer7-protocol="Block Dump" protocol=tcp reject-with=tcp-reset
add action=drop chain=forward comment="Drop ROPLOS --> WAN" src-mac-address=48:5B:39:AA:0B:90
Isn’t “action=passthrough” just counting the packet and not actually accepting it?
Can you try with action accept?
In firewall “pass through” means not that packet is accepted, only passed to next rule…
Try with “accept” instead of “passthrough”.
