I have added IP addresses from the /28 to Router2 ETH5 as required ie 123.123.123.17/28, 123.123.123.17/28, 123.123.123.18/28 etc.
Here is the odd issue.
The only way I can use the individual /28 addresses is to add them to Router1 1st and then remove them. It’s as if I have to tell Router 1 they are in service, however I thought I had already done that in my static route.
So, your /28 allow you to have 14 hosts.
As far as I can tell, you have a 123.123.123.16/28
You assign 123.123.123.17/28 to your bridge and 123.123.123.18/28 123.123.123.19/28 etc to clients behind the bridge.
Correct so far?
I haven’t actually assigned an address to the bridge as I have created a static route so I didn’t think it was neccessary and a waste of an IP. Perhaps this is where I am going wrong?
Devices, using those public adresses, need a route back to internet via their gateway. The easiest way is to assign one of those addresses to the bridge and use it as gateway address for the rest.
Another possibility is to use point-to-point routing (both ends use completely unrelated addresses), but that’s slightly more complicated to setup - not all devices support that in same way.
The example IPs I am posting are causing confusion for myself.
I have setup many Miktorik routers but only using PPPoE or Ethernet. I have never used a router behind a router and this is where I am getting in a muddle. I am sure it’s so simple but I just cannot see the wood from the trees. Sorry!
Please be patient with me while I start again. This time using IPs closer to my actual ones so I don’t confuse myself and everyone else!
123.123.123.192/27
Subnet Mask 255.255.255.224
Default Gateway 123.123.123.193 (Cisco)
First Usable 123.123.123.194/27 (Router1 ETH10)
Last Usable 123.123.123.222
I would like to give Router 2 a /28.
Here is what I have so far.
Router 1 (ETH9) 123.123.123.209/28 > Router 2 (ETH5) 123.123.123.210/28
The Cisco expects to be able to make an ARP request for any address from .194 to .222. As you are routing the upper half of a physical /27 subnet elsewhere ARP requests will fail, you need to enable proxy ARP on the router 1 interface connected to the Cisco.
Proxy ARP is also required if you hand out individual addresses from an physical subnet to PPPoE or VPN clients.
@tdw Thank you so much for the explanation and not making me feel an idiot. You were indeed correct. I would have never of found that without your help.
