Routing question/problem
So, I have 3 MT’s, A, B and C. A & B have 3 interfaces. C have 5 interfaces.
Both A and B are connected to C, to a separate interface.
Router A has
192.168.100.0/24 on eth if
192.168.101.0/24 on wlan1 if (AP mode)
10.1.1.2/30 on wlan2 if (client mode)
Router B has
172.17.1.0/24 on eth if
172.17.2.0/24 on wlan1 if (AP mode)
10.5.0.2/30 on wlan 2 if (client mode)
Router C has
192.168.1.0/24 on eth if
10.52.0.0/24 on wlan1 if (AP mode)
10.51.0.0/16 on wlan2 (client mode)
10.1.1.1/30 on wlan3 (AP mode)
10.5.0.1/30 on wlan4 (AP mode)
I have the following routes on the Router C:
 #     DST-ADDRESS        PREF-SRC        G GATEWAY         DIS INTERFACE
 0 ADC 10.1.1.0/30        10.1.1.1                              DAKKYNET-BB-YAGI
 1 ADC 10.5.0.0/30        10.5.0.1                              DAKKYNET-BB-kant
 2 ADC 10.51.115.49/32    10.51.115.53                          pppoe client
 3 X S 10.51.0.0/16                       u 172.16.51.1
 4 ADC 10.52.0.0/24       10.52.0.1                             DAKKYNET-panel
 5 ADC 10.100.0.0/24      10.100.0.1                            DAKKYNET-BB-YAGI
 6 ADC 172.16.51.0/26     172.16.51.60                          FREE NET-KANT
 7 A S 172.17.1.0/24                      r 10.5.0.2            DAKKYNET-BB-kant
 8 A S 172.17.2.0/24                      r 10.5.0.2            DAKKYNET-BB-kant
 9 ADC 192.168.1.0/24     192.168.1.252                         ether1
10 X S 192.168.20.0/24                    u 192.168.1.254
11 A S 192.168.100.0/24                   r 10.1.1.2        0   DAKKYNET-BB-YAGI
12 A S 192.168.101.0/24                   r 10.1.1.2        0   DAKKYNET-BB-YAGI
13 X S 0.0.0.0/0                          u 10.24.0.3       100
14 X S 0.0.0.0/0                          r 10.1.1.2            DAKKYNET-BB-YAGI
15 AD  0.0.0.0/0                          r 10.51.115.49    1   pppoe client
Currently, from Router C I simply can not ping the router B. Not even the gateway address - 10.5.0.2 … but, MAC ping goes, and MAC telnet works. And on the other side there is active 10.5.0.2 address… needless to say that pinging 172.17.1.254 (IP of the eth if on Router B) doesnt succeed either.
Currently, I can only restart the router without changing anything. After restart, the ping will succeed.
After restart, this is the route table:
As you can see I’ve been trying like everything… disabling, adding removing etc… Could it be because of distance? It just got to me, is MT maybe using the wrong route because of 0 distance?
edit_: tried to change distane to 1 for all routes, no difference. Whenever I disable the link to a router B, and enable it, the route goes down and it doesn’t get back up without a restart of a router…
Thank you in advance
Dakky
Plese make a drawing of this net and i’ll help.
/Henrik
Here you go mate…
Pretty quickly did draw this, maybe there’s an error…
Note that there are more non-intelligent switches in the network, but I drawn only one just to point for that…
And by the way as you can see, there is no fifth interface in the router C, drawn that on purpose as that if is going to stay disabled and removed soon.
Please show me your interface configurations on all wireless links
/Henrik
Router C - Dakky- roof
 0  R ;;; BACKBONE SHVELE
      name="DAKKYNET-BB-YAGI" mtu=1500 mac-address=00:30:4F:3A:2D:52 arp=enabled
      disable-running-check=no interface-type=Atheros AR5213 radio-name="Belveder/Centar"
      mode=ap-bridge ssid="DakkyNET-Belv-BB" area="" frequency-mode=manual-txpower
      country=croatia antenna-gain=17 frequency=2417 band=2.4ghz-b/g scan-list=default
      rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
      supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
      basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
      ack-timeout=dynamic tx-power=30 tx-power-mode=all-rates-fixed
      noise-floor-threshold=default periodic-calibration=enabled
      periodic-calibration-interval=60 burst-time=disabled dfs-mode=none
      antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-default-cost=100
      wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled
      default-authentication=no default-forwarding=no default-ap-tx-limit=0
      default-client-tx-limit=0 proprietary-extensions=post-2.9.25 hide-ssid=yes
      security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms
      preamble-mode=both compression=yes allow-sharedkey=no
 1 X  ;;; LINK NA FREENET
      name="FREE NET-KANT" mtu=1500 mac-address=00:14:78:7A:C9:C6 arp=enabled
      disable-running-check=no interface-type=Atheros AR5213 radio-name="dicman"
      mode=station ssid="Riwireless.net-Belveder" area="" frequency-mode=manual-txpower
      country=no_country_set antenna-gain=5 frequency=2442 band=2.4ghz-b/g
      scan-list=default rate-set=default supported-rates-b=1Mbps
      default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
      default-client-tx-limit=0 proprietary-extensions=pre-2.9.25 hide-ssid=no
      preamble-mode=both compression=no allow-sharedkey=no
 2  R ;;; BACKBONE POLJANE
      name="DAKKYNET-BB-kant" mtu=1500 mac-address=00:19:E0:84:AB:F9 arp=enabled
      disable-running-check=no interface-type=Atheros AR5213 radio-name="Belveder-Icici"
      mode=ap-bridge ssid="DakkyNET-Test" area="" frequency-mode=manual-txpower
      country=croatia antenna-gain=0 frequency=2432 band=2.4ghz-b scan-list=default
 3  R ;;; KLIJENTI BELVEDER
      name="DAKKYNET-panel" mtu=1500 mac-address=00:19:E0:84:B2:F6 arp=enabled
      radio-name="Belveder-Klijenti" mode=ap-bridge ssid="DakkyNET-Belveder" area=""
      frequency-mode=manual-txpower country=croatia antenna-gain=0 frequency=2457
      band=2.4ghz-b/g scan-list=default rate-set=default
      noise-floor-threshold=default periodic-calibration=default
      default-client-tx-limit=0 proprietary-extensions=post-2.9.25 hide-ssid=no
Router A - Poljane
 0    name="gornja-ap" mtu=1500 mac-address=00:19:E0:8C:69:C4 arp=enabled
      radio-name="dNet-Poljane-cvor" mode=ap-bridge ssid="DakkyNET-Poljane"
      area="" frequency-mode=manual-txpower country=no_country_set
      antenna-gain=0 frequency=2442 band=2.4ghz-b scan-list=default
                          54Mbps
      ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
      periodic-calibration=default periodic-calibration-interval=60
      burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled
      wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
      default-authentication=yes default-forwarding=no default-ap-tx-limit=0
      hide-ssid=no security-profile=default disconnect-timeout=3s
      on-fail-retry-time=100ms preamble-mode=both compression=no
      allow-sharedkey=no
 1  R name="donja-backbone" mtu=1500 mac-address=00:19:E0:8C:60:4C arp=enabled
      radio-name="dNet-bb-Poljane" mode=station ssid="DakkyNET-Test" area=""
      frequency-mode=manual-txpower country=no_country_set antenna-gain=0
      frequency=2427 band=2.4ghz-b scan-list=default rate-set=default
                          54Mbps
      wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
      update-stats-interval=disabled default-authentication=yes
      default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
Router B - Shvele
 0  R name="BACKBONE DAKKYNET" mtu=1500 mac-address=00:14:78:7A:C8:7A
      arp=enabled disable-running-check=no interface-type=Atheros AR5213
      radio-name="Svele" mode=station ssid="DakkyNET-Belv-BB" area=""
      frequency=2417 band=2.4ghz-b scan-list=default rate-set=default
                          54Mbps
 1    name="wlan1" mtu=1500 mac-address=00:19:E0:8D:65:48 arp=enabled
      radio-name="BK-KROV" mode=ap-bridge ssid="DakkyNET-Belveder-SatN"
      area="" frequency-mode=manual-txpower country=croatia antenna-gain=0
      frequency=2457 band=2.4ghz-b/g scan-list=default rate-set=default
                          54Mbps
      update-stats-interval=disabled default-authentication=no
      default-forwarding=no default-ap-tx-limit=0 default-client-tx-limit=0
Anything wrong?
It looks like you have your transmit power set for 1W at all datarates. I have never seen a card that can do that – where did you get it?
Those are the cheapest cards available, they cost around 30$, TP-Link cards… http://www.tp-link.com
Only one in the system is Planet card…
There is no information that these cards supports 1W.
Since you have configured tx-power to 30, you are overriding wireless card tx-power and damaging wireless card.
Set back tx-power-mode=default.
I will but still doubt that will solve my first problem? The one about the routes :slight_smile:
Still need your IP configuration m8
/Henrik
