I have a little problem that I hope someone can help me with.
What I am doing is using Router OS to switch between two vpn gateways on our network (providing multiple vpn failover using scripts which change static routes). The router is at x.x.x.125/25 and the gateways are at x.x.x.124/25 & .126/25 What is happening is : after the first connection is made from one host pc to another through the vpn, the router is bypassed by the host pc by an entry that appears in its route table (xp).
ie.
tracert x.x.x.131 ( which is at another location )
x.x.x.125
x.x.x.126
x.x.x.131
the next time I try:
tracert x.x.x.131
x.x.x.126
x.x.x.131
and a route is in the pc’s routing table bypassing the gateway
x.x.x.131 … x.x.x.126
I have tried other routers and this change ( in the host’s routing table) does not happen, but they lack netwatch and scripting capability. Does anyone know how I can stop this from happening?
The registry patch mentioned in the article along with changing [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters]
“EnableICMPRedirect”=dword:00000000 will enable the failover circuits that I have in place. Now to find a way to make this router stop broadcasting them will be my next step.
