Routing question
I have a question about setting up a static route. I have a router connected in client mode to to the routerboard. I need to log into it and cannot get the route set up. It was handed an IP of 192.168.2.245 and its local ip is 192.168.138.101.
What destination address and gateway do I use?
Lyle
You ned to have the IP’s in same l2 subnet. eg 192.168.1.x/24 must have a 192.168.1.x ip.
2.X and 138.X dont usually add up.
If its like. 2 subnet and you need to route. the routers will need a ip in both subnet each.
