When doing an export, Routing rules are not exported.
Also
It would be good if print in /ip route would do a (left) join with the /routing table and
display the table it is using.
Currently I am putting a comment in the route, to match the route to a table (and it’s creation statement)
add comment=“via 93” distance=50 dst-address=0.0.0.0/0 gateway=192.168.93.1
pref-src=“” routing-table=via-93 scope=30 target-scope=10 type=unicast
;;; via 93
6 AS 0.0.0.0/0 192.168.93.1 50
Regards
Roger
