Routing Test in Beta
As was explained at the recent MUM, there should be a Routing-Test package for the Beta versions. Here is what I heard at the MUM:
In RouterOS 2.9, you have:
Routing Package
-or-
Routing Test Package
In RouterOS 3.0, the 2.9 Routing-Test became Routing and there is supposed to be a newer Routing-Test for 3.0. Is this correct? If so, where is the 3.0 Beta Routing-Test package?
that’s old information, now there is no more test in v3 beta.
How do you setup an interface route in v3?
Just use the interface name as the “gateway” parameter. I’m not sure, but I believe in the beta you have to do this via the command line (i.e. no WinBox yet).
Best regards,
Christian Meis
