I have disabled routing-test package and enabled routing package.
When routing package was enabled routing was not functional.
Then I attempted to enable routing-test package and rebooted the router and nothing was done.
Both routing packages was disabled and only routing package can be enable, that not works.
Which version do you use ?
How do you enable ‘routing-test’ package ?
What do you have at ‘system package print’ ?
Do you use any dynamic routing procol (as there is no sence in routing package unless dynamic routing protocols are used) ?
How do you enable ‘routing-test’ package (you should 'system package enable routing-test, then system reboot) ?
