How to annonce networks using routing-test package???
/routing filter
Specify a newly created filter as out-filter parameter for a particular peer.
that’s good, but can you explain it in more details??
I mean “/routing filter add” attributes are quite unfamilliar for me
Come on please… tell me ![]()
This manual section is being worked on. I suggest hitting the tab key twice and seeing what options you can try…
John
I did that… even looked with add ? but no info at all… I can’t see any way to annonce with routing-test
