I have a couple of domains hosted behind my mikrotik.
When I access these domains from the WAN they work well and are correctly routed to the web server.
When I access them from within my local network I end up on the Mikrotik’s Web configuration utility.
I would like to 80 and 443 directed to the web server (unless I override this with a specific IP address).
Thanks and stay safe
Search for the word “hairpin”…yes really.
https://wiki.mikrotik.com/wiki/Hairpin_NAT
anav
March 28, 2020, 2:11pm
3
The WIKI is less than useful for the person that doesnt understand Mikrotik hieroglyphics…
Okay PF needs
A single firewall rule to allow destination packets to reach server (provided in the default rules setup)
A single source nat rule to keep track of outgoing packets assigned the router WANIP outbound (sourcenat if a fixed IP, masquerate action if a dynamic wanip)
If you wish to access the server from the same subnet the server is on, simply use the LANIP of the server.
If you wish to access the server by using the WANIP of the router (as if you were external) but from the same subnet as the server that is called HAIRPIN NAT and you will need
an xtra source nat rule and will need to modify potentially the destination nat rule (depending upon if WANIP is static or dynamic.
For each server you will need a single destination nat rule
If you can limit the external wanips requiring access to the the server, then use source-address-list in the destination nat rule (this changes port scans from closed to invisible).
As per paragraph 4 above, Hairpin nat is required when people IN THE SAME SUBNET as the server are trying to access the server via the WANIP of the router.
Its much easier to access the server directly by its LANIP address but apparently is not always the case.
What one needs to know is if your WAN connection is dynamic or static?
(1) Regardless of that there is one extra source nat rule for the hairpin functionality that we have to include that works in both cases.
add chain=srcnat action=masquerade src-address=192.168.88.0/24 dst-address=192.168.88.0/24 (replace with the subnet your server and users are on)
(2) For the default or regular source nat rule (use a. masquerade for dynamic wanip, use b. srcnat for static/fixed wanip)
a. add chain=srcnat action=masquerade out-interface-list=WAN ( I think for ppp0e connection one has to use the out-interface=pppoe-out interface. )
b. add chain=srcnet action=src-nat out-interface-list=WAN to-address=WANIP
(3) For the required destination nat rule the simple case is for the fixed WANIP since we know its IP.
add chain=dstnat action=dst-nat dst-address=FIXEDWANIP dst-port=80 protocol=tcp
to-addresses=192.168.88.2
(4) For the required destination rule in the complex case wanip dynamic we have to be tricky. Since we don’t know how to identify directly the incoming WANIP, we get around that with the dst-address-type ‘local’ entry, which says the destination address is on the router . We also state that the destination address is not the subnet (which leaves the router interface and thus the wanip).
add chain=dstnat action=dst-nat dst-port=80 protocol=tcp d st-address=!192.168.88.1
dst-address-type=local to-addresses=192.168.88.2
Okay PF needs
a. add chain=srcnat action=masquerade out-interface=WAN ( I think for ppp0e connection one has to use the out-interface=pppoe-out interface. )
b. add chain=srcnet action=src-nat out-interface=WAN to-address=WANIP
Thanks. I will try it and report back
I am trying to execute the following (I have a fixed public IP address)
add chain=srcnat action=masquerade src-address=192.168.16.0/24 dst-address=192.168.16.0/24
add chain=srcnat action=src-nat out-interface=WAN to-address=WANIP
add chain=dstnat action=dst-nat dst-address=xxx.xxx.xxx.180 dst-port=80 protocol=tcp to-addresses=192.168.16.5
add chain=dstnat action=dst-nat dst-address=xxx.xxx.xxx.180 dst-port=443 protocol=tcp to-addresses=192.168.16.5
When the line
executes I receive the error “input does not match any value of interface” I tried both WANIP as well as my fixed IP address (xxx.xxx.xxx.180)
anav
March 30, 2020, 7:40pm
6
Not seeing the complete config its hard to say…
add chain=srcnat action=src-nat out-interface-list=WAN to-address=WANIP
to
add chain=srcnat action=src-nat out-interface=WAN to-address=xxx.xxx.xxx [/color]
Below is an export of the config. Any suggestions to improve greatly apprecaited.
# mar/30/2020 22:27:45 by RouterOS 6.45.8
# software id = 0E9A-7W1F
# model = RouterBOARD 952Ui-5ac2nD
# serial number = 665805xxxxx
add admin-mac=E4:8D:xx:xx:xx:xx auto-mac=no comment=defconf name=bridge
add name=bridge-guest
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
country=italy disabled=no distance=indoors frequency=auto mode=ap-bridge \
ssid=HOMENET-AP wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX country=italy disabled=no distance=indoors frequency=\
auto mode=ap-bridge ssid=HOMENET-AP wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=<<password>> \
wpa2-pre-shared-key=<<password>>
add authentication-types=wpa2-psk eap-methods="" management-protection=\
allowed mode=dynamic-keys name=guest supplicant-identity=MikroTik \
/interface wireless
add disabled=no mac-address=E6:8D:8C:D6:E4:5E master-interface=wlan1 name=\
"Guest Wifi" security-profile=guest ssid=HomeNet-Guest \
wds-default-bridge=bridge wps-mode=disabled
add name=dhcp ranges=192.168.16.20-192.168.16.99
add name=dhcp_vpn ranges=10.8.2.10-10.8.2.49
add name=dhcp_guest ranges=10.10.10.2-10.10.10.128
add address-pool=dhcp disabled=no interface=bridge lease-time=23h59m59s name=\
local
add address-pool=dhcp_guest disabled=no interface=bridge-guest lease-time=59m \
name=dhcp-guest
/ppp profile
add dns-server=10.8.2.250 local-address=10.8.2.250 name=vpn-profile \
remote-address=dhcp_vpn use-encryption=yes
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge-guest interface="Guest Wifi"
/interface detect-internet
set detect-interface-list=all
/interface ovpn-server server
set auth=sha1 certificate=server-certificate cipher=aes128,aes192,aes256 \
default-profile=vpn-profile enabled=yes require-client-certificate=yes
add address=192.168.16.1/24 comment=defconf interface=ether2 network=\
192.168.16.0
add address=213.165.177.180/27 interface=ether1 network=<<fixed WAP IP>>
add address=10.10.10.1/24 interface=bridge-guest network=10.10.10.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
add address=10.10.10.0/24 dns-server=8.8.8.8,9.9.9.9 gateway=10.10.10.1
add address=192.168.16.0/24 comment=defconf gateway=192.168.16.1 netmask=24
set allow-remote-requests=yes servers=1.1.1.1,9.9.9.9,8.8.8.8
/ip dns static
add address=192.168.16.1 name=router.lan
add action=accept chain=input comment="Allow OpenVPN" dst-port=1194 protocol=\
tcp
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat comment=HTTP dst-port=80 in-interface=ether1 \
protocol=tcp to-addresses=192.168.16.4 to-ports=80
add action=dst-nat chain=dstnat comment=HTTPS dst-port=443 in-interface=\
ether1 protocol=tcp to-addresses=192.168.16.4 to-ports=443
add action=dst-nat chain=dstnat comment="RSB SFTP port" dst-port=5552 \
in-interface=ether1 protocol=tcp to-addresses=192.168.16.5 to-ports=22
add action=masquerade chain=srcnat dst-address=192.168.16.0/24 src-address=\
192.168.16.0/24
add distance=1 gateway=xxx.xxx.xxx.161
/ip service
set www disabled=yes
set www-ssl certificate=Webfig disabled=no
/ppp secret
add name=<<user>> password=<<password>> profile=vpn-profile
/system clock
set time-zone-name=Europe/Italy
/system identity
set name=onn.com
/tool mac-server
/tool mac-server mac-winbox
Regards and Thanks
to
mkx
March 30, 2020, 8:44pm
8
When the line
executes I receive the error "input does not match any value of interface" I tried both WANIP as well as my fixed IP address (xxx.xxx.xxx.180)
It should be out-interface-list=WAN
anav
March 31, 2020, 5:50pm
10
What is the difference between out-interface=Wan, and out-interface-list=WAN in the general case? (when one only has one wan).
When having multiple WANs, or some funky pppoe setup, I can see the need…
mkx
March 31, 2020, 7:38pm
11
If “wan” is name of interface list, even if it only has one member, then one has to use in-interface-list. If, OTOH, “wan” is name of interface, then one has to use in-interface.
Essentially if interface list has a single member, then there’s no difference in functionality. However, use of interface list (and hence in-interface-list) offers versatility … if one changes wan interface, then in case of using interface list it is enough to adjust interface list membership. Uf one uses interface directly, then many changes are needed (every firewall rule referencing now ex- wan interface).
I expect that performance-wise there’s no big difference (if any).
