I am trying to work with a similar setup, where I have a RB493AH sitting at the base of our tower, and use it to hand out DHCP to customer routers. I am not worried about static addresses for right now, but rather, I am wondering how to get to the private subnet (10.0.0.0/8) that our radios are addressed on from outside the NAT. When I connect a router to a subscriber radio, and set it for DHCP, it communicates properly with the RB493AH, pulling a private address which NAT’s to the public address of the mikrotik. The problem that I am having is that I cannot access the radios which are doing the bridging on the internal side of the RB493AH. Is there a static route I need to add, or a dst-nat solution? I am simply stuck.
It’s not completely what you are trying to do, but if you are trying to access the 10.0.0.0/8 subnet from the wan, then a dst-nat is what you need.
Pick a for each device and dst-nat to :. then access your devices on :
If a few other things are correct, you’ll be able to access the devices.
