routing traffic between 2 router boards
morning all.
I have 2 router boards, a RB1100 and a RB951. the 951 is currently acting as a wireless router for guest, internal and general networks, and the RB1100 is doing all the major work (firewall, NAT, routing, Load balancing multiple WAN connections, etc).
I have 3 networks on the 951 (192.168.88.x for general internet, 89.x for guest and 90.x for internal). the RB1100 has 192.168.0.x for all traffic at the moment… the plan is the 90.x will be able to see machines on the 0.x network (on the RB1100), the 89 will only have basic network access (rate limits, etc) and the 88 will be able to see all internet, but no machines…
at the moment, the 951 is connected to the 1100 and is getting a 0.x ip and natting all traffic to the internet… I am a bit lost as to how to set it so i can create 3 separate routes for the 951 to setup the trafic as above… Any tips?!
Thanks.
