uh.. it was too late yesterday - The ugly “no internet” and the /32 error shouldn’t happen
- thanks for finding it!
But the missing rules at (5) are already there:
/routing rule
add action=lookup-only-in-table comment=“allow local traffic when required”
min-prefix=0 table=main
add action=lookup-only-in-table disabled=no src-address=192.168.90.0/24
table=to-Fritz
I changed it like you said. But I don’t see any traffic over vlan30 - just a short spike at ether3 when broadcasting for an IP address.
So in the end, the client at ether3 doesn’t get a 192.168.90-IP
Here’s my config (I made a Diff with a Diff-Tool to make sure that I changed everything you said):
# 2024-07-09 10:35:20 by RouterOS 7.15.2
# software id = MRVG-J4JI
# model = C52iG-5HaxD2HaxD
# serial number = ***
add admin-mac=48:A9:8A:DA:A7:5E auto-mac=no comment=defconf name=bridge
/interface wireguard
add listen-port=182** mtu=1420 name=wireguard1
/interface vlan
add interface=ether1 name=ether1.1 vlan-id=2
add interface=ether3 name=vlan30 vlan-id=30
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1.1 name=pppoe-out1 \
use-peer-dns=yes user=4036121000
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi datapath
add bridge=bridge comment=defconf disabled=no name=capdp
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .reselect-interval=\
1h..1h20m .skip-dfs-channels=10min-cac .width=20/40/80mhz \
configuration.country=Austria .mode=ap .ssid=P-Wave datapath=capdp \
disabled=no security.authentication-types=wpa2-psk,wpa3-psk \
.connect-priority=0 .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.band=2ghz-ax .reselect-interval=\
1h..1h10m .skip-dfs-channels=10min-cac .width=20/40mhz \
add name=dhcp_vlan30 ranges=192.168.90.2-192.168.90.254
add address-pool=default-dhcp interface=bridge name=defconf
add address-pool=dhcp_vlan30 interface=vlan30 name=dhcp_vlan30
/routing table
add disabled=no fib name=to-Fritz
/disk settings
set auto-media-interface=bridge
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
/interface wifi cap
set discovery-interfaces=bridge enabled=yes slaves-datapath=capdp
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=yf8bw8kpxtav0ktp.myfritz.net \
endpoint-port=558** interface=wireguard1 name=peer1 persistent-keepalive=\
25s preshared-key="***" \
public-key="***"
192.168.88.0
add address=192.168.90.1/24 interface=vlan30 network=192.168.90.0
add address=192.168.80.4/24 interface=wireguard1 network=192.168.80.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
192.168.88.1
add address=192.168.90.0/24 dns-server=192.168.80.1 gateway=192.168.90.1
set allow-remote-requests=yes
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=accept chain=forward comment="internet traffic" in-interface-list=\
LAN out-interface-list=WAN
add action=accept chain=forward comment="allow V30 to tunnel" out-interface=\
wireguard1 src-address=192.168.90.0/24
add action=accept chain=forward comment="port forwarding" \
connection-nat-state=dstnat
add action=drop chain=forward comment="drop all else"
/ip firewall mangle
add action=change-mss chain=forward new-mss=1420 out-interface=pppoe-out1 \
passthrough=yes protocol=tcp tcp-flags=syn
add action=change-mss chain=forward comment=\
"Clamp MSS to PMTU for Outgoing packets" new-mss=clamp-to-pmtu \
out-interface=wireguard1 passthrough=yes protocol=tcp tcp-flags=syn
ipsec-policy=out,none out-interface-list=WAN src-address=192.168.88.0/24
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wireguard1 \
routing-table=to-Fritz suppress-hw-offload=no
/ip service
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/routing rule
add action=lookup-only-in-table comment="allow local traffic when required" \
add action=lookup-only-in-table disabled=no src-address=192.168.90.0/24 \
table=to-Fritz
/system clock
set time-zone-name=Europe/Vienna
/tool mac-server
/tool mac-server mac-winbox
