Routing vs bridging
Hi all!
For about four years i had bridged network, it grows up very large and now when some device crash my entire system become unstable.
I want to migrate to routed network, i have public and static ip addresses on my access points, and some static routes, which is better way to
start: dynamic or static routing? i don’t know very well how to use static routes, is there some example how to start and which is the painless way?
Thanks again!
if you plan to continue to grow, then better opt for dynamic routing. eg. OSPF
Hi!
I want to start using OSPF but i don’t know how.
I tried to search in google for a example posts, but it looks like it’s very complicated, i need some simple examples:
1.when i activate OSPF, then i need to remove bridges?
2.In my links i still use ap bridge+station wds to connect two sites?
3.I can add static routes too?
Sorry for much questions!
Thanks in advance!
