Routing with 2 routers and than INTERNET
I have 2 routers.
One security router with IPS and so.
Than an Mikrotik RB-951G 2HnD (for wifi and hotspot
See my drawing.
On the Mikrotik I have to set the routings but I can’t get it working
What routings do I have to add?
On the security router I add 2 manual routings
Source Destination Gateway Metric
any 192.9.10.0/24 192.168.1.1 1
any 192.9.20.0/24 192.168.1.1 1
any 192.9.201.0/24 192.168.1.1 1
You probably want a default route ( to 0.0.0.0/0) from the Mikrotik to the outer router. Are these 192.9.x.x addresses public IPs allocated to you?
Sorry, I don’t know what you mean.
The 192.9.x.x addresses are internal addresses.
Used for LAN.
The 80.101.110.68 is The address I got from my ISP
192.9.x.x is not an internal address range and should be not used as such, but you are free to do whatever you like if you keep it behind NAT. You are likely not NATig that range and that is why your system is not working.
I recommend changing those localnets to
192.168.10.1/24
192.168.20.1/24
192.168.201.1/24
and routing those subnets to MK1 in your security router.
Insure router MK1 has no srcnats or masquerades, and a default route like this
add gateway=192.168.1.254
Hi Thanks for your reply.
Now with my old adresses it is working but I can not reach all interent sites.
Some sites are not working.
Is this because the addresses I use?
I will change it in your suggestions.
You are using a public network space as a internal network. So that address range of the Internet is not reachable by you, but I think it is not the case here. You should post your config.
