Hello everyone,
my current setup includes a main network 192.168.0/23 with 3 WAN interfaces with PPPoE.
I am trying to add another isolated network (192.168.20.1/24 Guest) in which a Unifi AP will provide internet access to guests through one of my 3 WANs. My Unifi Controller is hosted in the main network 192.168.1.XX
I have used ether5 as the LAN for the main network and ether4 as the LAN for the Guest Network.
In my current setup, devices in the Guest network can ping and connect to IP addresses in the main network but not the other way another. For example i can not ping or connect to a PC connected to the Guest network.
- What is wrong with the current setup that disables routing between the 2 networks?
- What is the best/safest way to allow access from the Guest network only to the IP Address of the Unifi controller for AP to fetch settings and for end users to see the Guest portal?
- How can I route the Guest network through one of the 3 WAN?
Thanks in advance
Panagiotis
Please find below my current configuration.
# may/08/2020 18:24:25 by RouterOS 6.46.5
# software id = BSX4-P5PU
# model = 2011UiAS
# serial number = B914xxxxxxx
add name=GUEST
add name=LAN
/interface pppoe-client
add add-default-route=yes comment="WAN_3" default-route-distance=3 \
disabled=no interface=ether3 max-mru=1492 max-mtu=1492 name=\
pppoe-out_210xxxxxxx password=nxxxxxx user=xxxx@otenet.gr
add add-default-route=yes comment="WAN_2" default-route-distance=2 \
disabled=no interface=ether2 max-mru=1492 max-mtu=1492 name=\
pppoe-out_211xxxxxxx password=xxxxxxx user=xxxxxx@tellas.gr
add add-default-route=yes comment="WAN_1" disabled=no interface=ether1 \
max-mru=1492 max-mtu=1492 name=pppoe-out_211xxxxxxx password=xxxxxx \
user=xxxxxxx@tellas.gr
/ip dhcp-server option
add code=43 name=unifi value=0x0104C0A801A4
add name=dhcp_pool0 ranges=192.168.0.2-192.168.0.254
add name=dhcp_pool1 ranges=192.168.20.2-192.168.20.239
add address-pool=dhcp_pool1 disabled=no interface=GUEST name=DHCP_GUEST
/ip hotspot user profile
set [ find default=yes ] address-list=allowed_internet_ips3 address-pool=\
dhcp_pool1
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=LAN interface=ether5
add bridge=GUEST interface=ether4
add address=192.168.1.1 interface=LAN network=255.255.254.0
add address=192.168.1.250 interface=LAN network=255.255.254.0
add address=192.168.20.1/24 interface=GUEST network=192.168.20.0
/ip dhcp-server lease
add address=192.168.20.246 mac-address=78:8A:20:F0:6F:8C server=DHCP_GUEST
add address=192.168.20.247 mac-address=C4:E9:84:59:41:29
add address=192.168.20.0/23 dhcp-option=unifi dns-server=8.8.8.8,8.8.4.4 \
gateway=192.168.20.1
set servers=8.8.8.8,8.8.4.4
/ip firewall address-list
add address=192.168.1.254 list=allowed_internet_ips3
add address=192.168.0.1-192.168.0.32 list=allowed_internet_ips
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
add action=accept chain=input connection-nat-state=dstnat connection-state=\
established,related,new in-interface=pppoe-out_211xxxxxxx
/ip firewall mangle
add action=accept chain=prerouting in-interface=pppoe-out_211xxxxxxx
add action=accept chain=prerouting in-interface=pppoe-out_210xxxxxxx
add action=mark-connection chain=prerouting dst-address-type=!local \
in-interface=LAN new-connection-mark=WAN1_conn passthrough=yes \
src-address-list=allowed_internet_ips
in-interface=LAN new-connection-mark=WAN2_conn passthrough=yes \
src-address-list=allowed_internet_ips2
add action=mark-routing chain=prerouting connection-mark=WAN1_conn \
in-interface=LAN new-routing-mark=WAN1_route passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN2_conn \
in-interface=LAN new-routing-mark=WAN2_route passthrough=yes
in-interface=LAN new-connection-mark=WAN3_conn passthrough=yes \
src-address-list=allowed_internet_ips3
add action=mark-routing chain=prerouting connection-mark=WAN3_conn \
in-interface=LAN new-routing-mark=WAN3_route passthrough=yes
add action=masquerade chain=srcnat out-interface=pppoe-out_211xxxxxxx \
add action=masquerade chain=srcnat out-interface=pppoe-out_210xxxxxxx \
add action=dst-nat chain=dstnat dst-port=443 in-interface=\
pppoe-out_211xxxxxxx protocol=tcp to-addresses=192.168.1.113 to-ports=443
add action=dst-nat chain=dstnat dst-port=3391 in-interface=\
pppoe-out_211xxxxxxx protocol=udp to-addresses=192.168.1.113 to-ports=\
3391
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
src-address=192.168.20.0/24
add distance=1 gateway=pppoe-out_211xxxxxxx routing-mark=WAN1_route
add distance=1 gateway=pppoe-out_211xxxxxxx routing-mark=WAN2_route
add distance=1 gateway=pppoe-out_210xxxxxxx routing-mark=WAN3_route
add distance=1 dst-address=192.168.0.0/23 gateway=LAN
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
/ip ssh
set strong-crypto=yes
/lcd
set enabled=no
/system clock
set time-zone-name=Europe/Athens
/tool traffic-monitor
add disabled=yes interface=pppoe-out_211xxxxxxx name=tmon1
