Hi guys,
I have a mikrotik RB751G-2HnD. I configure with IPsec:
my lan: 10.10.0.0/24
remote lan: 192.168.30.0/24
this is work OK, but now i need to add route to subnet 192.168.0.0/16
if i set a static route (/ip route add dst-address=192.168.0.0/16 gateway=94.134…
I can’t ping anything from this subnet.
Any advice, what to do?
Are you using IPSec in transport mode or tunnel mode?
Hi Tom,
I use Tunel (if you mean checkbox in IPsec Policy..)
You can not do routing with IPSec in tunnel mode. If you wanna do routing, you need to use IPSec in transport mode with any other tunneling protocol. (Like L2TP/IPSec)
This is very strange, because before mikrotik we used a old Vigor router, and there was no problem to add static route to another subnet on 2nd side of tunel and gateway was public IP of router on 2nd side…
Are you sure that the Vigor used IPSec in tunnel mode as opposed to a GRE/IPIP/PPP-like tunnel with IPSec in transport mode?
Feel free to watch the presentation in my sig for an overview of L2TP/IPSec.
Yep, Vigor is in tunel mode https://dl.dropboxusercontent.com/u/15890750/router_vigor.pdf there is no L2TP client..
S~ 192.168.40.0/ 255.255.255.0 via 95.80.x.x, VPN
S~ 192.168.0.0/ 255.255.0.0 via 95.80.x.x, VPN
