Notebook is connected by wifi to Mikrotik1 to wlan1, on mikrotik1 I have static routes between wlan1 a eth1, so I can ping from my notebook everything on Mikrotik1, but I can’t ping Mikrotik2 , which is connected with LAN cable to Mikrotik2. How can I set-up the routes to ping Mikrotik2 from my notebook ? I don’t want to use any NAT or bridge, just only routes … Thank you for your time to reply.
Have you set on your laptop 192.168.100.1 as the default gateway?
Have you set on your Mikrotik2 192.168.0.1 as the default gateway (or as a static rule)?
MikroTik1 knows how to get to MikroTik2 via its default gateway. (and out via MikroTik2’s gateway.
MikroTik1 and two can ping each other because they are linked by their common ethernet leg.
Here is the issue..
MikroTik2 does NOT know obout the 192.168.100/24 network.
Add a static route on MikroTik2 for 192.168.100.0/24 with a gateway 192.168.0.1. The router will “pick” the correct interface (wlan1).
Baisickly, the routers know how to send packets forward in your network (twards the gateway), but MikroTik2doesnt know how to get packets back to the far end of MikroTik1
(I have done this with a 10X network.. I have NOT tried this with a 192X)
(I also cant remember if any firewall rules are nessisary on MikroTik1 IE: all traffic from 102.168.0/24 to 192.168.100.0 accept. due to the fact you are crossing the firewall “inbound” with a non routable IP range)
Note: if MikroTik1 was running as a masquerade, for the 192.168.100.XXX network, this would not be needed.
Note2: Routing discovery protocols IR RIP,OSPF etc would also help here.
So, if the gateway are correctly setted (or static roule correctly implemented), there shouldn’t be any problem, but I suspect that pastik hasn’t setted up properly his Mikrotik (or laptop).
Here some hints:
Or set a static roule on Mikrotik2, such as: net 192.168.100.0/24, gw 192.168.0.1, but it’s the same thing of setting a 192.168.0.1 on it’s default gateway.
Yes, no logical difference between 10.x and 192.x (or 172.x).
Thanks for your time, but I think I’ve already done it. It doesn’t work. The setting of my notebook is ok, but how to set-up routes between MK1 and MK2 … there will be a problem although you can ping each other mikrotik directly, but from notebook I have no chance to ping MK2 …
Here is the issue..
Yes the gateway setting shows MikroTik1 the way out via MikroTik2, but it does nothing to inform MikroTik2 that it (MikroTik1) “hosts” the 192.168.0.X network.
MikroTik2 will recieve a packet from the “100” network, try to look it up in its route table, find no entries and forward it out its default gateway which is out the wrong intrerface.
You need some wat to tell MikroTik2 where the 100 network is.
“Gateway” or “default routes baisickly do the folowing: " I have a packet and I don’t know where to send it, OK, shove it out here and let the up stream router figure it out..” Only you need the packet to go “down stream”.
You need a static route on MikroTik2 for the 100 net with MikroTik 1 as its’ gateway. (or enable a routing protocol between the routers. That will do the same thing but with more work for such a simple net.)
