Routing Worked then Stopped
I was wondering if you could shed some light on this. I don’t know if you have experience with Mikrotik, but I know you have experience with routers in general. Last night I was setting up a Mikrotik box with the following setup:
Have to use the 3com router in between because plugging in the modem directly into the Mikrotik does not establish a link for some reason.
The Mikrotik also runs 3 more networks with 10.59.1.0/24, 176.16.0.0/16, and 192.168.1.0/24 networks. All 3 networks had DHCP servers enabled on their interfaces. I had it setup so all the networks used 192.168.254.1 as their default gateway and they could see eachother via source and destination NATs. I also setup some bandwidth throttling and a little bit of QoS. Seemingly, I had everything working.
When I plugged into each network interface using a laptop and a straight through cable and everything seemd to work. I could ping outside and do DNS queries as well as browse the web, etc. when I plugged into every interface. After some cable management was done, however, and the Mikrotik was hooked back up I could no longer ping 192.168.254.1. Consequentially I couldn’t get to anywhere on the net.
If you knew anything that could cause this or maybe just give some helpful helpful insight on this situation.
The default gateway on each network has to be an IP address on that network. So, for example, on 192.168.1.0/24 the gw should be 192.168.1.1. The MT router should have a default gateway of 192.168.254.1.
Regards
Andrew
you’d be suprised but it doesn’t have to be.
Yes, I’m surprised. Without using proxy-arp?
The gateway is the next hop address. The client has to be able to reach it with a layer 2 broadcast in order to determine where to send the ethernet frame.
Explain.
Regards
Andrew
Yes.
That’s correct (for non point-to-point links, anyway) but some
routing platforms have a mechanism
called “recursive route lookup”, whereby direct Layer-2 reachability
of the next-hop may be deduced in multiple steps by recursively
looking up gateways until one with direct Layer-2 reachability
is indeed found.
According to
http://www.mikrotik.com/download/CHANGELOG_beta
What's new in v2.9beta1:
*) routes now support recursive nexthop lookup;
So this works starting with 2.9
–Tom
Tom
Thanks for the explanation. Looks like I’m behind the curve again. Time for some more reading :open_mouth:
Regards
Andrew
