Routing
Help me please with routing, i have 3 ip addresses on one GW, i hink that is the problem, now i have ping to 8.8.8.8 (only) with “no route to host”, i don’t understand why
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=45.154.116.1 pref-src="" routing-table=main scope=30 \
    suppress-hw-offload=no target-scope=10
add check-gateway=ping disabled=yes distance=1 dst-address=77.88.55.0/24 gateway=172.16.10.1 pref-src="" \
    routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=ping comment=********* disabled=no distance=1 dst-address=192.168.3.0/24 gateway=10.0.49.11 \
add check-gateway=ping comment=********* disabled=no distance=1 dst-address=192.168.6.0/24 gateway=10.0.49.14 \
add check-gateway=ping comment=********* disabled=no distance=1 dst-address=192.168.7.0/24 gateway=10.0.49.15 \
add check-gateway=ping comment=********* disabled=no distance=1 dst-address=192.168.8.0/24 gateway=10.0.49.16 \
add check-gateway=ping comment=********* disabled=no distance=1 dst-address=192.168.9.0/24 gateway=10.0.49.17 \
add check-gateway=ping comment=********* disabled=no distance=1 dst-address=192.168.10.0/24 gateway=10.0.49.18 \
add check-gateway=ping comment=********* disabled=no distance=1 dst-address=192.168.12.0/24 gateway=10.0.49.20 \
add check-gateway=ping comment=********* disabled=no distance=1 dst-address=192.168.13.0/24 gateway=\
    192.168.5.172 pref-src=0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=ping comment="*********" disabled=no distance=1 dst-address=192.168.15.0/24 gateway=\
    172.22.22.2 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=ping comment=********* disabled=yes distance=1 dst-address=213.180.193.58/32 gateway=\
    172.16.10.1 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=ping comment=********* disabled=yes distance=1 dst-address=213.180.204.242/32 gateway=\
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=45.154.116.1 pref-src="" \
    routing-table=ISP1-Route scope=30 suppress-hw-offload=no target-scope=10
    routing-table=ISP2-Route scope=30 suppress-hw-offload=no target-scope=10
    routing-table=ISP3-Route scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=ping disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=172.16.10.1 pref-src="" \
    routing-table=Yandex-Route scope=30 suppress-hw-offload=no target-scope=10
add check-gateway=ping comment=********* disabled=yes distance=1 dst-address=5.255.255.0/24 gateway=\
add check-gateway=ping comment=********* disabled=yes distance=1 dst-address=77.88.55.0/24 gateway=\
add check-gateway=ping comment=********* disabled=no distance=1 dst-address=192.168.88.0/24 gateway=172.22.23.2 \
add check-gateway=ping comment=********* disabled=no distance=1 dst-address=192.168.2.0/24 gateway=10.0.49.12 \
add check-gateway=ping comment=********* disabled=yes distance=1 dst-address=193.200.32.16/32 gateway=45.154.116.1 \
    pref-src=45.154.116.xx routing-table=main scope=30 suppress-hw-offload=no target-scope=10
