Hi all!
What src-address do packets generated by router itself have?
Illustration
Addresses:
1. address=1.1.1.1/24 interface=ether1-gateway
2. address=2.2.2.1/24 interface=ether5-local
Route table:
1. Active dst-address=0.0.0.0/0 gateway=1.1.1.254
2. Active dst-address=0.0.0.0/0 gateway=1.1.1.254 routing-mark=R1
3. Active dst-address=0.0.0.0/0 gateway=2.2.2.254 routing-mark=R2
Route rules:
1. src-address=1.1.1.1 table=R1
2. src-address=2.2.2.1 table=R2
If all 3 routes are active, then outbound packets go through specific gateway. It is ok.
But if I deactivate the second route, the outbound traffic will go through the first gateway according to the 1 route! I don’t understand why?
Why the rule 2 aren’t implemented? It is obvious I have a misunderstanding of the routing rules.
Thx!!!
