Hello, is possible, when the traffic tracked via SNMP is zero(0) or less 500kbps to make notification via email or other thing?
Thans in advice.
Greeting from Bulgaria.
Soon i will record some videos for my MikroTik links and HotSpot server ![]()
Sure, you can create such probes easily, but you’d have to get into SNMP and the syntax of probes and experiment a little.
See the ‘Probe Thread’ (here) for some examples and go from there…
realy thanks! ![]()
