RS 5.0b6 Plz help os crash x86
I have os crash it wan’t load … each time it goes to fcsk check it sad error fix and reboot … but after reboot i have same issue …
i need any way to make backup of config to reinstall …
Thanks alot for any advice …
P.S. it works under VM Esxi
v5 RC1 is on stage =)
p.s. NetInstall should save your current config, if it’s saveable…
fixed through reinsta’l from CD with save old parametrs…
