RS125-24G-1S-2HnD-IN as a simple router config needed
can anyone share a config for RS125-24G-1S-2HnD-IN so it behaves as a simple router?
Ether1: WAN DHCP client ( DSL Router/Modem IP: 10.0.0.1)
Ether2-24: LAN DHCP server, switched
  • also this network will have VoIP traffic, i want to disable all firewall for clean testing.
  • also change the network IPs range from 192.168.88.* to 192.168.1.*
Why did you bought this kind of router then?
Use your ISP router and an unmanaged switch.
Thats simple
here is what i want to do:
  • i have a DSL Router-Modem connected to my ISP. the DSL Router IP Address is 10.0.0.1 , i have disabled the DHCP on this router.
  • i have connected the mikrotik ETH1 to the DSL Router ETH1
  • i have 5 Desktops connected to ETH-2-3-4-5 ( many will be added later ).
  • i have 2 Access Points connected to ETH6 & ETH7, and many mobile clients will connect to the internet from these Access Points ( will add more later ).
  • the mikrotik also have a built in WiFi, many mobile clients will use it for connection.
    how do i configure this setup ?
i have tryed many things, but field, now i factory reset the mikrotik, the current IP address is 192.168.88.1
i want my lan to be in the range 192.168.1.*
also i don’t want any firewall on, i want any client connected to ping and browse any other client on the network, i will add firewalls later after i install the VoIP server and configure every thing.
Removed all the Multicast (IPTV) & VPN related config, also specific config to my setup is removed, including Firewall rules.
And pretty much this is what was left and should do it:
set [ find default-name=ether1 ] name=ether01-inet-gw
set [ find default-name=ether2 ] name=ether02-lan-master
set [ find default-name=ether3 ] master-port=ether02-lan-master name=
ether03-lan-slave
set [ find default-name=ether4 ] master-port=ether02-lan-master name=
ether04-lan-slave
set [ find default-name=ether5 ] master-port=ether02-lan-master name=
ether05-lan-slave
set [ find default-name=ether6 ] master-port=ether02-lan-master name=
ether06-lan-slave
set [ find default-name=ether7 ] master-port=ether02-lan-master name=
ether07-lan-slave
set [ find default-name=ether8 ] master-port=ether02-lan-master name=
ether08-lan-slave
set [ find default-name=ether9 ] master-port=ether02-lan-master name=
ether09-lan-slave
set [ find default-name=ether10 ] master-port=ether02-lan-master name=
ether10-lan-slave
set [ find default-name=ether11 ] master-port=ether02-lan-master name=
ether11-lan-slave
set [ find default-name=ether12 ] master-port=ether02-lan-master name=
ether12-lan-slave
set [ find default-name=ether13 ] master-port=ether02-lan-master name=
ether13-lan-slave
set [ find default-name=ether14 ] master-port=ether02-lan-master name=
ether14-lan-slave
set [ find default-name=ether15 ] master-port=ether02-lan-master name=
ether15-lan-slave
set [ find default-name=ether16 ] master-port=ether02-lan-master name=
ether16-lan-slave
set [ find default-name=ether17 ] master-port=ether02-lan-master name=
ether17-lan-slave
set [ find default-name=ether18 ] master-port=ether02-lan-master name=
ether18-lan-slave
set [ find default-name=ether19 ] master-port=ether02-lan-master name=
ether19-lan-slave
set [ find default-name=ether20 ] master-port=ether02-lan-master name=
ether20-lan-slave
set [ find default-name=ether21 ] master-port=ether02-lan-master name=
ether21-lan-slave
set [ find default-name=ether22 ] master-port=ether02-lan-master name=
ether22-lan-slave
set [ find default-name=ether23 ] master-port=ether02-lan-master name=
ether23-lan-slave
set [ find default-name=ether24 ] master-port=ether02-lan-master name=
ether24-lan-slave
set [ find default-name=sfp1 ] disabled=yes
add name=dhcp-lan-pool ranges=192.168.1.2-192.168.1.250
add address-pool=dhcp-lan-pool disabled=no interface=ether02-lan-master
lease-time=1h name=dhcp-lan
add address=192.168.1.1/24 interface=ether02-lan-master network=192.168.1.0
/ip dhcp-client
add comment=Internet dhcp-options=hostname,clientid disabled=no interface=
ether01-inet-gw
add address=192.168.1.0/24 dns-server=192.168.1.1 domain=local.lan
gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes cache-size=8192KiB max-udp-packet-size=4096
add action=masquerade chain=srcnat comment=Local-Lan out-interface=
ether01-inet-gwBut be careful, as there is no Firewall rules present on this config, so nothing protects your network and Router. :exclamation:
As mine doesnt have Wireless (CRS125-24G-1S-RM), I have absolutely no idea about the wireless config part :wink:
But I suspect that you have to create a Bridge interface and assign that IP on that,
instead of ether2-lan-master and attach ether2 & wireless to it, effectively bridging them both together.
All the other part of the config should be pretty much same.
