I need to make a project to pass a RS232 signal of one “relé” (I don’t know this in .uk…perhaps relay..) between 2 buildings. This Relé has 2 states.. open or close and i need to put this open/close signal in the remote building of the link. Can I connect it directly to rs232 of a third routerboard?
I’ll put a link and I can put more routerboards if I need it.
Hello onnoossendrijver.
thanks for your quick response.
the idea is to use the RS232 port the Mikrotik, not use RS232/IP gateway add to Mikrotik.
the premise is founded, have one equip that do all=> Wireless RS232 converter and inversely.
It is possible with Mikrotik?
continue to dialogue, thanks, regards.
Ah… Ok.. I misunderstood.
I believe this feature was recently added to a beta release and removed one release later because it’s was not stable.
So I don’t think it’s possible unfortunately.
