Hi
Can someone point me to a working RSSI probe example for v4.03.
I have read " Getting started with functions and probes", “quick guide to a good probe”
But to no avail, just cant get a working probe/function.
Through copying and modifying other examples, I have managed to get “low signal” displayed but inverted to actual.
And also “not available” plenty of times.
I have tried with zeros at the end of the oid, 2 methods to remove the negation, but no luck.
I have read that there is a subtle difference in the “available” pre-requisites in v4.03, something to do with -1 or 1 or 0..
And as far as the documentation goes, it seems vague in a few areas.
Lebowski, in the “Quick guide…”, half way down the page you start to use, 10, 29 at the end of the oid… I have seen other examples of this (10,5) What is the significance of those values added into the end of the oid expression???
What is the difference between oid_raw and oid_column.
I have trawled the web, but cannot find any explanation at all.
I know someone is going to be willing to offer up an RSSI probe/function, but thats not the point..
I want to know what is different in 3.6 to 4.03 and the significance to those values added to the oid.
