Good evening,
Here is the configuration of my network:
knowing that wireless connections may alternatively be cut. To avoid cutting the flow of data between the camera and the PC I tried to build bridges RSTP but I can not do with wireless links. Is this possible? whether it should use the PTS and especially how?
I also try to use the HWMP + but I can not do at all would it be more appropriate?
Can anyone help me? thank you in advance
