rstp+log
hi2all
anyone help with this
there is 2 mikrotik with rstp bridge. somtimes it’s goes down and in the log i see folowing
16:01:45 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:01:46 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:01:49 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:01:52 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:01:53 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:01:55 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:01:56 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:01:57 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:01:58 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:02:00 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:02:02 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:02:05 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:02:07 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:02:11 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:02:12 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:02:16 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:02:17 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:02:19 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:02:20 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:02:24 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:02:25 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:02:27 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:02:29 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:02:30 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:02:32 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:02:33 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:02:36 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:02:38 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
16:02:39 radvd,warning neighbor fe80::edfc:dd4f:6755:ef2 on bridge1 uses other stateful configuration
what its mean?
