It seems there is a problem with determining the right Bridge Root in RSTP.
Here is my scenario:
- HP v1910-48G - STP enabled. Mode RSTP. Bridge Priority 4096 (0x100 hex in Mikrotik)
- hAP-Lite with Switch chip defined VLANs and a Bridge with all ports and WLAN1 adapter. (I also disabled Switch Assisted VLAN - switch-cpu1 - disabled.. same result)
- Bridge is in RSTP mode with admin-mac set. Bridge Priority is default 8000 (32768 in decimal .. which use HP)
- hAP-Lite is connected via ether1 and should be the root port in CST Bridge
The calculated bridge Root is always hAP-itself..
Which is not correct. Even if it has lower MAC the Bridge priority is higher than HP and thus cannot be root bridge..
I have trieed ROS 6.46.8 and ROS 6.48.
Interesting it works on CRS212 using ROS 6.46.8.
RSTP is also broken on CSS1106 in SwOS 2.12 which I reported in Annoucement thread.
It seems there is somekind of bug or I am missing something.
Here is the config of hAP-Lite if someone wanna give it a go and try.
set [ find default-name=ether1 ] name=ether1-uplink
set [ find default-name=ether2 ] name=ether2-Zunanji
set [ find default-name=ether3 ] name=ether3-Zunanji
set [ find default-name=ether4 ] name=ether4-Zunanji
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-Ce \
disabled=no distance=indoors frequency=auto installation=indoor mode=\
ap-bridge ssid=Pubs station-roaming=enabled vlan-id=24 vlan-mode=\
use-tag wireless-protocol=802.11
add admin-mac=E4:8D:8C:CD:58:26 auto-mac=no comment=defconf name=bridge
/interface vlan
add interface=bridge name=vlan15-Management vlan-id=15
set 0 vlan-mode=secure
set 1 default-vlan-id=24 vlan-header=always-strip vlan-mode=secure
set 2 default-vlan-id=24 vlan-header=always-strip vlan-mode=secure
set 3 default-vlan-id=24 vlan-header=always-strip vlan-mode=secure
set 4 vlan-mode=secure
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=\
fsdgjffd874 wpa2-pre-shared-key=Strojniki@Pisker2020
/snmp community
add addresses=172.16.15.0/24 name=SCP
add bridge=bridge comment=defconf interface=ether2-Zunanji
add bridge=bridge comment=defconf interface=ether3-Zunanji
add bridge=bridge comment=defconf interface=ether4-Zunanji
add bridge=bridge interface=ether1-uplink
add ports=switch1-cpu,ether1-uplink switch=switch1 vlan-id=15
add ports=\
switch1-cpu,ether1-uplink,ether2-Zunanji,ether3-Zunanji,ether4-Zunanji \
switch=switch1 vlan-id=24
add ports=switch1-cpu,ether1-uplink switch=switch1 vlan-id=39
add ports=ether1-uplink switch=switch1 vlan-id=21
add ports=ether1-uplink switch=switch1 vlan-id=37
add ports=ether1-uplink switch=switch1 vlan-id=20
add comment=defconf interface=ether1-uplink list=WAN
add interface=vlan15-Management list=LAN
192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=vlan15-Management
set allow-remote-requests=yes
established,related,untracked
invalid
in-interface-list=!LAN log=yes
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
connection-state=new in-interface-list=WAN log=yes
