RSTP question with 3 paths
I have a test setup using RSTP that is as follows:
SwitchA connects to Switches B, C, D.
B<>C
C<>D
All traffic is flowing from A to B and A to D, but C only gets traffic via B or D. Even though C is only one hop from A.
Am I approaching this wrong?
I basically just bridged the interfaces and enabled RSTP. All links are the same speed etc. I’d like traffic to be able to traverse from A to C directly, A to B and A to D directly as well. If any of the A to ? links should fail, the other links will allow the traffic to go around the outage.
Thanks!
This is exactly the behavior of spanning tree. On a redundant network it will disable paths in order to avoid loops. So you’ll see that sometimes traffic flows in a way that’s counter intuitive.
what you’re trying to achieve involves making A the root bridge. Lower the bridge priority on A and it should converge the way you want.
Enviado desde mi MotoE2(4G-LTE) mediante Tapatalk
Awesome, thanks! That did the trick! I have always used OSPF so this is a new attempt at dealing with failover and it is working great now.
