RSTP SWITCH FEATURE ROS>6.38.1
Hello I have tested the switch feature of RSTP. At these moment I can’t see how we can change the path cost of the dynamic ports inside the brige. It appears that all dynamics ports are configured with 10 in path cost. It will be possible change in new ros versions? Is there some way to do these?
Thanks a lot.
Xicu
Same problem. I need change patch cost… but i cant becouse the interface is dynamic.
