I have USB HDD connected to my 2011 and sharing(using SMB) files to my home network.
Once per day I want to syncronize data on my remote server to this HDD.
I imported public ssh key to mirkrotik and now able to ssh or scp.
Normally I use rsync for such purposes but in case with MT it doesn’t work.
Example:
/usr/bin/rsync -e ssh --progress -lzuogthvr /home/rsync admin-ssh@xx.xx.xx.xx:/usb1/test
protocol version mismatch – is your shell clean?
(see the rsync man page for an explanation)
rsync error: protocol incompatibility (code 2) at compat.c(173) [sender=3.0.7]
after some googling found that problem likely in banner which mikrotik shows when you tries to login.
Does anybody know how to fix it? or maybe alternative(secured) way to sync folders with remote linux.
