Rsyslog parser for Mikrotik proxy
Hi
can any one write a parser script for rsyslog so that i can parse and store mysql proxy log to database
current message format is
Receivedat: 2013-09-27 17:11:07
Facility: 1
Priority: 5
FromHost: 172.30.0.xxx
Message: 172.16.0.xxx GET http://google.co.in action=allow cache=MISS
SysLogTag: web-proxy,account
i want it to be stored in database like
Client IP: 172.16.0.xxx
Url: http://google.co.in
status: MISS
Provider: web-proxy
Looks like you never got a reply to this.
I am wondering about whether to do the same thing,
…or attempt to write a script to clean things up before leaving the Mikrotik router.. e.g. just keeping the Response to "GET http:’ and ‘Content-Length:’ lines and then send those via a HTTP GET?
Mark
For what its worth, the webproxylogtomysql.php in Proxylizer does a pretty good job of recording URL requests, domains and HIT/MISS requests in Mysql via syslog-ng. It comes with a small crontab wrapper script that keeps it running. It takes the output of a named pipe fed by syslog-ng and pushes everything into Mysql.
The rest of Proxylizer (report generation, mailing etc) is a little broken now, especially if your running PHP5, as theirs a lot of deprecated stuff in there now. (e.g ereg and use of DB.php)
yes, proxylizer is a bit outdated now. And since there is allmost no interest in it, it will stay like this.
Want to share my script, wich convert rsyslog mkaccess.log file to squid format.
mkaccess.log: no debug, only simple one-record-per-line format.
There is no size(fake size, 1024 per string), no dst-host ip(fake ip 8.8.8.8), only datetime, local ip and url persist
Output can be used on linux-tools like lightsquid etc.
#!/usr/bin/perl -w
use Date::Parse;
$num_args = $#ARGV + 1;
if ($num_args != 1) {
    # mkaccess.log - syslog's file, mikrotik remote logging.
    print "\nUsage: ".$0." /path/to/mkaccess.log\n";
    exit;
open (IN, "<".$ARGV[0]) || die $!;
while(<IN>){
    chomp;
    ($line)=join " ",(split / /)[1,0,2,3,4,5,6,7,8];
    $line =~ s/^\s+//gi;
    $line =~ s/(\s+)/ /gi;
    my($day,$mns,$time,$hname,$host,$method,$site,$access) = split('\s+', $line);
    ($date)=join " ",$day,$mns,$time;
    $dateepoch=str2time($date." +0200");
    if ($access eq 'action=allow') {
        $string=$dateepoch.".000 999 ".$host." TCP_MISS/200 1024 ".$method." ".$site." - DIRECT/8.8.8.8 text/html\n";
        print $string;
close IN;
Hi, guys!
I wrote simple one-line script based on script posted near year ago. Script worked like a charm(i think) and faster than perl-script. 8 min vs more than 10 hours. I hope this line help some one.
Thats it: cat log_from_mikrotik.log |grep -v ‘action=deny’|awk -F"MSRRTR01 proxy:" ‘{system(“date +%s.000 -d "”$1""");print("1 "$2)}’|sed ‘:a;N;0~2!ba;s/\n/ /g;’|awk -F" " {‘print $1" “$2” “$3” TCP_MISS/200 100 “$4” “$5” - DIRECT/0.0.0.0 text/html\n\r"’} > converted.log
